Front Suspension squeek
Discussion in '1st Gen. Tacomas (1995-2004)' started by fishtaco73, Jul 29, 2011.
  1. Jul 29, 2011 at 8:45 PM
    fishtaco73
    fishtaco73 [OP] New Member
    Dave
    San Diego
    04 Doublecab 4x4
    Hi all,
    I've got a 2004 Doublecab 4x4 that I bought used last year. The prior owner put in aftermarket front shocks that squeek and groan all the time. I'm wondering if there might be an easy fix, such as changing some bushings or something similar? May'be i should just replace the front shocks altogether? Your thoughts on this dilemma are much appreciated!
    Dave
  2. Jul 29, 2011 at 9:03 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    there is a chance its the ball joints
  3. Jul 29, 2011 at 10:06 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Check and see if the coil is rubbing on anything. Check and see if the balljoints are ripped/torn.
  4. Jul 29, 2011 at 10:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Depending on a lot a factors, there have been instances where the bottom shock bushings have worn. Take a look to see if the rubber has been pushed out. Jack up one corner and see if you can move the shock. lol, you shouldn't be able to.
