Front suspension, stock vs Rough Country
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tluke81, Sep 16, 2021.
  1. Sep 17, 2021 at 9:24 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    They're expensive for a reason. The more you lift, the more you fuck up your drivetrain's geometry.
    You can choose to heed all of the advice above or not. It's your truck and your lesson to learn.
  2. Sep 17, 2021 at 9:31 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    You actually only want about 2”
    JayRolla, Tocamo and supmet like this.
  3. Sep 17, 2021 at 9:31 AM
    FireGuy88
    FireGuy88 Well-Known Member
    Southern California
    2016 Red TRD Off-Road
    Take a look at the eibach stage 1 or stage 2 kit, it’s a great product with tons of reviews, and eibach is a reputable company. If you want at least 3” your gonna need upper control arms.
    The kit is about $650
    UCAs can be about $400-$800
    I went with the stage 1 kit, put it on the 2nd notch and got about 2.5” of lift, didn’t need UCAs
  4. Sep 17, 2021 at 9:32 AM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    He's building a mall crawler, he doesn't care about his CV angles.
  5. Sep 17, 2021 at 9:55 AM
    BasicallyTaco
    BasicallyTaco Well-Known Member
    Ga
    2021 Tacoma SR5 2WD silver, "basic little truck"
    Don't go cheap dude. It usually ends up costing you more in the end than just doing it right the first time.
  6. Sep 17, 2021 at 10:04 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It’s not just about cv angles. In fact that might not be a concern at all. As I said above, the truck comes with 3” of down travel from the factory. For each 1” of lift (when using a coil over replacement) you lose 1” of down travel. Zero down travel is a bad idea. The tires will have a hard time staying in contact with the ground.
    Either way, I don’t see how bad cv angles are acceptable for a daily driver.
  7. Sep 17, 2021 at 11:08 AM
    Clearwater Bill
    Billy
    Largo Florida
    The 3" RC 'lifted struts' are spacers AFAIK. It's one reason why they are cheap.
    Maybe not. Ok, probably not.
    Not doing it. 2 to 2.5 is about all you want to avoid introducing a whole 'nuther set of problems and expenses.
    You might want to do some reading and reevaluate your goals. Or not. For as the infamous @Rock Lobster says,
    Hope it all works out for you.........
  8. Sep 17, 2021 at 11:15 AM
    gudujarlson
    Minnesota
    I didn't know what "lifted struts" were either, so I went to the rough country website and looked. They appear to be coil overs, but I could not find any information on spring rate, spring length, preload, or an estimation of lift besides the "3in" in the product title (which is the same regardless of whether you select spacers or "lifted struts" from the options). I suspect they are designed to give ~2" lift on a stock truck with no added weight.
  9. Sep 17, 2021 at 11:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    In my SCCA suspension play days, the dearth of info like that on a product always meant 'move along' to me. ;)
    Good products will include the deets. Including ones I didn't even know I needed to know. :anonymous:
  10. Sep 17, 2021 at 11:24 AM
    gudujarlson
    Minnesota
    I was turned off by that too. I think I may have been even more tuned off by the images they choose to display the product with. They have several images of a truck driving through a puddle in a parking lot. wtf?
  11. Sep 17, 2021 at 11:29 AM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    That’s essentially what the OP sounds like he wants to do..
  12. Sep 17, 2021 at 11:35 AM
    ArmyWulfman
    ArmyWulfman Well-Known Member
    Nick
    Central VA
    2021 Army Green TRD Sport
    For what it’s worth, OP, I’ve not been on TW very long but I’ve been modifying cars and trucks since before I could drive and been on various forums even longer. It might seem like you’re getting a lot of flak and you might not like what you hear but listen to these guys that have probably seen RC issue threads pop up over and over. Take advantage of the collective knowledge and avoid the cheap shit.
    Also, looked up the RC product page. There’s a shocking lack of info on those components. Just a lot of words like smooth ride, lift expectations, and other things to put the buyer at ease.
  13. Sep 17, 2021 at 12:55 PM
    tluke81
    tluke81 [OP] Active Member
    Thanks for the recommendation, ill check them out
  14. Sep 17, 2021 at 12:57 PM
    tluke81
    Thanks for the good response, so many people seem to be salty about a question, I am going to avoid RC after seeing what people said. The only reason I was set on it was because of the price + good reviews on the website I was on (extreme terrain).
  15. Sep 17, 2021 at 12:59 PM
    #35
    tluke81
    Thanks for the useful responses, ill check out other companies and go down to 2.5
  16. Sep 17, 2021 at 12:59 PM
    #36
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Bilstein 5100's at 2" with a 1 inch spacer and AAL would have you in at under $1,000 including strut/spring build and alignment if installing yourself. Would also me much better that RC.
  17. Sep 17, 2021 at 2:08 PM
    #37
    gudujarlson
    Minnesota
    Why combine a spacer with a preload-adjustable shock? It seems like doing it right and doing it wrong at the same time.
    BasicallyTaco likes this.
  18. Sep 17, 2021 at 2:59 PM
    #38
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Love my 2/1" Bilstein 5100 Lift. Only a 1" Block in the rear. Looks nice and lifted, and still feels like original ride. (Basically the OEM TRD lift at less than half the cost).
    Wouldn't be worth it for me to want a 3" Lift, especially a spacer lift.
  19. Sep 17, 2021 at 3:06 PM
    #39
    CalcityRenegade
    2023 T4R ORP KDSS
    It is an option if he wants a decent 3" set up without just sticking a 3" puck up front. Ride quality would be just fine. Guys add 1" leveling kits to TRD Pro Fox suspension so why not? Although I would avoid this is someone is doing severe off-roading.
  20. Sep 17, 2021 at 3:11 PM
    #40
    gudujarlson
    Minnesota
    I stated my concerns about top-of-coil spacers earlier in this thread. It comes with risks at full compression and full extension. You don't have to be off road to encounter those situations, but it is less likely for sure.
