Front suspension very soft and touchy
Discussion in 'Suspension' started by sarange, Nov 8, 2011.
  1. Nov 8, 2011 at 8:27 PM
    sarange
    sarange [OP] Member
    I have a 2003 Tacoma 4X4 crew cab. Recently I notice the front suspension is very touchy, soft and seems like catches the grooves on the highway and goes dizzy. I checked the front shocks, no leak or any damage....
    What is the problem? need help
  2. Nov 8, 2011 at 8:31 PM
    acdronin
    acdronin Well-Known Member
    Welcome to TW! Umm soft and touchy? Goes dizzy? Is your truck menstruating?:D:D:D:D
  3. Nov 8, 2011 at 8:34 PM
    acdronin
    Check to make sure all your lug nuts are correctly tightened, if one is loose, jack up the wheel and loosen and re-torque all of them on that wheel. For whatever reason, your alignment may be off. You probably should take it to an alignment shop and see if they can find anything.
  4. Nov 9, 2011 at 8:41 AM
    sarange
    sarange [OP] Member
    Thanks for the response, everything you mentioned is fine, could it I have bad shocks? but there are no leaks etc..
  5. Nov 9, 2011 at 8:45 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    If the shocks have not been replaced, it is likely that your shocks are bad. Soft shocks are a general indicator of this.
  6. Nov 9, 2011 at 8:53 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    x2 assuming that your running on either stock or older shocks, with them being "soft" it makes me think that its time to replace them and the springs. When you hit bumps does the front end continue to bounce up and down for a little while after?
  7. Nov 9, 2011 at 9:01 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    stand on the front bumper and bounce up and down. if theres not a lot of resistance and the truck bounces easily could be time for new shocks. how many miles are on the truck?
  8. Nov 10, 2011 at 4:45 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    My 02 is doing the same exact thing. Front end wants to wander where ever the hell it wants to. It catches every rut/crack in the road and follows it. Judging on the condition of my rear springs, I need new shocks all around. Either that or an alignment.
  9. Nov 20, 2011 at 11:57 PM
    sarange
    sarange [OP] Member
    Ok guys, I chaned the front struts, I still have same issue, the front wonders all over, I jacked up the front axle, move the tire, I noticed the rack and pinion housing moved slightly in the u shape rubber bushing, is that normal?
    Should I change all the bushings into polyeurethene? HELP?
