Front Suspension Woes. Input needed.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aray02, Jul 12, 2020.
  1. Jul 13, 2020 at 1:23 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Super easy. Spray some PB blaster on your old hardware and let sit before you take them off. Just use a floor jack to hold it all while you drop it. It's just some spacers and longer bolts.
    Aray02[QUOTED][OP] likes this.
  2. Jul 13, 2020 at 1:28 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Takes max of about 10 minutes.
    JJ04TACO and Aray02[QUOTED][OP] like this.
  3. Jul 13, 2020 at 4:14 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Very.
    Remove skids. Place jack under diff. remove the two bolts. Let the diff come down ~1" on the jack. Put in spacers and longer bolts. Tighten.
  4. Jul 13, 2020 at 4:32 PM
    Running Board Man
    Running Board Man Well-Known Member
    Is your uca hitting the coil
    Aray02[OP] likes this.
  5. Jul 13, 2020 at 5:34 PM
    Aray02
    Aray02 [OP] Well-Known Member
    Negative
  6. Oct 4, 2020 at 1:35 AM
    Truth
    Truth Active Member
    '98 Tacoma TRD Limited; 3.4L V6
    2” rear body lift, 2.25” rear suspension lift; 3” front body lift (it’s in a transition period); OME rear springs+an extra leaf; Bilstein 5100s in the front; BFG 31x10.5s
    what height adjustment is that on those bilsteins?!? looks like adjustment on the fly?
  7. Oct 6, 2020 at 7:13 AM
    Xbeaus
    Beau
    The coilover is adjustable. I called the guys at Toytec and they said for the best ride leave the bilstein height adjuster (as they are height adjustable as well) on the lowest setting. I did that and played around with what works best for my CV axles. With the diff drop I was comfortable with 1.75" of lift. Plenty for my pickup to fit 33" tires if I wantedt to. Running 265/75/16 and I like that setup. Plenty of clearance for an IFS pickup.
  8. Oct 6, 2020 at 8:15 AM
    Truth
    Truth Active Member
    Are they the Toytec Ultimate coilovers? Also, it looks like from the picture that they come pre-installed on Bilsteins... is that the case?
  9. Oct 6, 2020 at 9:31 AM
    Xbeaus
    Beau
    https://realtruck.com/p/toytec-toyota-coilover-shocks/
    This is where I got them about 6 years ago. They didn't call them ultimate coilovers then. They have Eibach springs with them. I had to assemble them and also replace the Top Hats (those don't come with) Upper part of the strut assembly.
