Front suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RodW98, Aug 20, 2022.
  1. Aug 20, 2022 at 8:56 PM
    RodW98
    RodW98 [OP] Member
    Brody
    2010 Toyota Tacoma Base
  2. Aug 20, 2022 at 9:08 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Welcome to TW.
  3. Aug 20, 2022 at 9:19 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Welcome!
    Depends on how much lift. What springs are you planning on using? Less than 2" you can go without new uca's. You don't need to mess with the lowers.
  4. Aug 20, 2022 at 9:22 PM
    RodW98
    RodW98 [OP] Member
    Brody
    Those specific shocks have 4 different lift adjustments i think the most it goes is 2.5" i believe, i was planning to use the oem springs unless i need knew springs also
  5. Aug 20, 2022 at 9:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The 5100a are made for OEM springs. This is what I’d use if you want to keep it simple and use the chart that the 5100s come with.
    If you run different springs, the settings will not be accurate.
    Some guys run aftermarket springs and set the 5100 to the first notch (lowest setting).
    The 5100s use the spring perch as a lift.
    Where as aftermarket coils use the spring as the lift.
    You shouldn’t really combine the 2.
    Read more on using after market springs here.
    https://www.tacomaworld.com/threads/5100s-with-ome-887-notch-setting-for-3-lift.589196/
    In short, Use the stock springs.
    And as a general rule, the closer you get to 3” of lift the more likely you will need UCA to get a good alignment.
  6. Aug 21, 2022 at 6:58 AM
    RodW98
    RodW98 [OP] Member
    Brody
    Okay thanks, i just checked out that link about aftermarket springs. A lot of it looked like they were saying the oem springs dont work with the bilstein 5100. But also what youre saying makes sense too. I just wanna get all the right stuff so i dont mess anything else up. So if i wanted to put the 5100s on the highest notch, would i need longer UCA or shorter?
  7. Aug 21, 2022 at 7:00 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    For what it’s worth I lifted the front of my 2015 about 2” and did not come close to needing new UCAs.
    RodW98[OP] likes this.
  8. Aug 21, 2022 at 7:08 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
