Front sway bar relocate kit... Needed for a lift?
Discussion in 'Suspension' started by HAWAIICALIVEGAZ, Dec 6, 2011.
  1. Dec 6, 2011 at 7:23 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ [OP] Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    I've got Icon front coilovers ready to put on but I don't have the sway bar relocate kit. I'll more than likely buy them but what's the reason for them and what would happen if I didn't use them with the truck lifted 3" with the coilovers?
    Also lets say when I get my spindles.. I "lower" my coilovers back down and lift the truck with the spindles. Will I need the sway bar relocate kit then??
    http://www.toyteclifts.com/index.ph...tegory_id=118&option=com_virtuemart&Itemid=72
  2. Dec 6, 2011 at 7:31 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Try it. After a couple weeks you'll be able to see if your sway bar is bumping your springs, because the paint at the contact point will wear off and youll have (maybe) a clank over some bumps.
    If so, then run the relocate.
  3. Dec 6, 2011 at 7:43 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Oh so it's not something that is NEEDED for the lift... I'll put them on anyway, since i'll have the truck apart. Do they come in different thickness's or all the same? If they are all the same... What do people do with a 6-8 inch lift?
  4. Dec 7, 2011 at 3:25 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You'll more than likely need them and i def wouldn't let them rub the shock and potentially damage anything! Or.........u could get rid of that sway bar altogether, it just gets in the way lol!
  5. Dec 7, 2011 at 3:32 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    I have icons and it is needed or the sway won't bolt up because it hits
    Your other option is lose the sway bar entirely which a ton of people do anyways
  6. Dec 7, 2011 at 3:56 AM
    Bz3r0
    Bz3r0 Smackalicious!
    Bryan
    Edwards AFB, CA
    White 2017 TRD Offroad
    Under Construction
    Yep.... Bought a 3" Toytec ultimate lift and the package came with the relocation clamps. You will notice like stated in posts above mine, things will be worn or... You won't be able to put the swaybar back in its original position because your coilovers will be in the way.
  7. Dec 7, 2011 at 4:06 AM
    c0b2a
    c0b2a Well-Known Member
    Was interested in getting these as well, anyone know if they will be needed / recommended with the OME coils in the front?
  8. Dec 7, 2011 at 4:20 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    Good question. Subbed for answer
  9. Dec 7, 2011 at 5:04 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I have the full OME set up and I had to put them on since when I go over bumps my sway bar hit the bottom of the coils.
  10. Dec 7, 2011 at 5:16 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I need to get them and i have eibachs wrapped around 5100s
  11. Dec 7, 2011 at 5:18 AM
    c0b2a
    Looks like I will be placing an order for them. Thanks for the info.
  12. Dec 7, 2011 at 6:38 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It occus to me that if you got 2.5" diameter coilovers, you will need the sway bar relocate kit.
    All it does is provide extra space between the bar and the spring.
  13. Dec 7, 2011 at 6:54 AM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    yeah I've noticed a lot of people have removed theirs, why is that? more articulation for crawling? do people still have the sway bar if they baja or DD their tacoma? I still drive my truck on the streets and like the safety aspect of it lol...
  14. Dec 7, 2011 at 6:58 AM
    c0b2a
    DD I would keep it on for sure.
  15. Dec 7, 2011 at 7:20 AM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    Loose the sway bar you'll will hardly tell the diference
  16. Dec 7, 2011 at 7:47 AM
    AzogSS
    Andy
    Soda City, SC
    What kind did you get?
  17. Dec 7, 2011 at 7:58 AM
    c0b2a
    Is that independent flex a result of loosing the sway bar?
  18. Dec 7, 2011 at 8:10 AM
    BulletToothTony
    It allows greater flex because it allows each to work totally independent of each other, the sway bar restricts it greatly. There are some pictures that demonstrate this in action alot better then my picture...
  19. Dec 7, 2011 at 10:43 AM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    I like how it flexes like that but will I benifit from removing the sway bar while bajaing?
  20. Dec 7, 2011 at 11:02 AM
    BulletToothTony
    I honestly dont know not to many sand dunes and desert running in South East Texas lol.
