Front Timbren bumps on 09' tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by robert benner, Feb 8, 2009.
  1. Feb 8, 2009 at 11:21 AM
    robert benner
    robert benner [OP] Member
    eastern PA
    09' taco sport dc lwb black
    TRD exhaust and intake, Shrockworks front bumper, AAL, full tint, 3/4" toytec spacer
    Any one out there installed front timbren bumps on their 09' tacoma. If so how did you get the old bump stop off, 16 mm wrench? Any insight would be great?
    Thanx. Rob
  2. Feb 8, 2009 at 11:30 AM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    I have them on my 07 taco, I used a pipe wrench to get the old ones off.
  3. Feb 8, 2009 at 11:32 AM
    colvilletacoma
    colvilletacoma Well-Known Member
    Central Washington
    Toyota Tacoma
    OME 886 Coils, Bilstein 5100's in Front, Tuff Country in Rear, Custom Racks with winch built in
  4. Feb 8, 2009 at 12:05 PM
    robert benner
    eastern PA
    Hello Kyle: How did you get at the factory nut? My 09' has very little room to get in there? Did yours have only one bumpstop? I know older taco's had two.
    Thanx. Rob
  5. Feb 8, 2009 at 12:11 PM
    silver07taco
    COIL
    Maryland
    Im not to sure what you are talkin about, You should just be able to unscrew the old bumperstops off and screw the new ones on.
  6. Feb 8, 2009 at 8:04 PM
    robert benner
    eastern PA
    My bumps on the 09' are mounted on the frame not on the lower UCA and I cannot really get to the nut it is protected by mounting area which surrounds it. Kyle did you just screw off the bump itself with the pipe wrench? How did you hold the nut while doing this?
    Thanx. Rob
  7. Feb 9, 2009 at 2:08 AM
    silver07taco
    COIL
    Maryland
    There wasnt a nut to hold on it, I belive its welded to the frame so all you have to do is unscrew the stock bumperstop.
