Front tire clearance issue
Discussion in 'Wheels & Tires' started by Joel_r1, Feb 2, 2018.
  1. Feb 2, 2018 at 12:39 PM
    Joel_r1
    Joel_r1 [OP] Member
    Joel
    Garden Grove, CA
    2004 Silver Double Cab SAS's Tacoma TRD SR5
    Custom Diamond front axle with Toy 8" from FJ60 with E-locker, stock rear axle housing with E-locker and Yukon chromoly shafts, 5.29 gears with 37x1250x17 Cooper STT PRO's on 17x10 Raceline Beadlocks, All-Pro Front bumper w/XRC9500 winch and 2 sets of Rigid Ind. LED lights. Demello rear bumper with Body Armor swing out tire carrier Frankensteined on. Demello Sliders, custom trailing arm to stop axle wrap. Deaver front springs and Alcan rear springs and On-board air with 2.5 gallon tank.
    Guys, I have 2013 Taco and running 33x11.50x16 Procomp Extreme AT's. I have the Procomp 2.5" coil spacer kit in there and have removed the mud flaps and trimmed as much of the plastic as I can in the rear of the wheel well but its still rubbing when turning into a driveway. I heard something about an adjustment to move the wheels forward a bit.
    Does anyone on here know anything about this?
    Thanks guys, this forum is awesome!
    scottsglock29 likes this.
  2. Feb 4, 2018 at 1:39 PM
    scottsglock29
    scottsglock29 Well-Known Member
    Scott
    Wisconsin
    2019 Cement TRD Sport DCSB
    New aftermarket UCA's will help. There are many out there to choose from. That would boil down to personal preference and budget.
    Edit: Also may need to consider a CMC. That will also help with clearance issues and rubbing.
  3. Feb 4, 2018 at 1:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    Max castor
    Likely will need UCAs to get enough.
    And you need to determine exactly where the rub is.
  4. Feb 5, 2018 at 7:37 AM
    Joel_r1
    Joel_r1 [OP] Member
    Joel
    Garden Grove, CA
    OK cool, thanks for the input guys. I will do my research on some UCA's.
    Thank s again!
  5. Feb 5, 2018 at 7:39 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Light Racing UCAs have adjustable Caster/Camber, while 'the rest' have a fixed addition of Caster
  6. Feb 5, 2018 at 7:50 AM
    Joel_r1
    Joel_r1 [OP] Member
    Joel
    Garden Grove, CA
    Great info, thank you!
