Front tires cupping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tammikm, Mar 23, 2020.
  1. Mar 23, 2020 at 5:53 PM
    tammikm
    tammikm [OP] Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    What causes the front tires to cup. I think that’s the term... the outside lugs on the front tires are worn on an angle Really strange looking. Just had an alignment and drives straight as an arrow???..
  2. Mar 23, 2020 at 5:55 PM
    NMroamer
    NMroamer Well-Known Member
    Fred
    Albuquerque
    2015 TRD OR
    That happens when you don't rotate the tires.
  3. Mar 23, 2020 at 5:56 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Too much toe in increases wear and feathering on outside edge of tires.
  4. Mar 23, 2020 at 7:41 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Or your alignment is out of order.
  5. Mar 23, 2020 at 7:43 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Are you lifted? Could be alignment. What tire and pressure do you run?
  6. Mar 24, 2020 at 5:01 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    To a point that is normal, when you go around a corner the outside edges of the front tires are getting a lot more weight placed on them. Rotating the tires often will help, less aggressive corning helps. During the time those tires are on the rear the wear will even things out.
    But if the wear is excessive you could have worn shocks or other suspension parts.
    ToyoTaco25, BillsSR5 and DaveInDenver like this.
  7. Mar 24, 2020 at 5:11 AM
    Stormtrooper457
    Stormtrooper457 Well-Known Member
    Indiana
    2013 TRD Sport DCLB
    Nano Ceramic Tint Heated Clazzio Seats TRD Pro Wheels Softopper
    Cupping can occur from not rotating your tires regularly, having a vehicle that is out of alignment, or from poor suspension/hub angles or failing parts.
  8. Mar 24, 2020 at 6:44 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Shocks...
  9. Mar 24, 2020 at 9:27 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Not rotating? I haven't bothered to rotate the tires on mine for years and have no cupping.
