Front tires scraping when you turn in reverse after long drive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sfbbqguy, Sep 22, 2014.
  1. Sep 22, 2014 at 1:53 PM
    sfbbqguy
    sfbbqguy [OP] Member
    Bay Area, CA
    '14 Dbl Cab 4x4 LB
    Anyone else notice front tires scraping or rubbing wheel wells or something when the truck is turned in reverse after traveling for longish periods on the highway?
    I've got a 14 double cab 4wd with rims that are very close to factory size and original factory tires. Normally no scraping or rubbing when fully cranked on any turn but it seems something in there is getting mis-shaped by the wind or something on long drives and causing this.
    Would like to know what it is if anyone has any insight. Asked dealer today but the seemed to know nothing.
  2. Sep 22, 2014 at 2:00 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    A light breeze or strong wind should have no bearing to the problem. Your aftermarket rims are not the correct size... that's my guess.
    BTW, the dealer won't lose sleep over this, as you have aftermarket equipment on it.
    Do you see marks where it is rubbing?
  3. Sep 22, 2014 at 2:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Your aftermarket wheels are probably the issue here.
    Did it do this before you replaced the wheels?
    If the answer to the above is No, we have the answer.
  4. Sep 22, 2014 at 2:18 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Not sure if it helps, but I had this problem when turning in reverse.
    As others mentioned, do you see any visible marks?
  5. Sep 22, 2014 at 2:25 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I say it's the wheels.
    Of course you could not back up.:)
  6. Sep 22, 2014 at 3:13 PM
    sfbbqguy
    Bay Area, CA
    '14 Dbl Cab 4x4 LB
    Thanks. Just not sure of what it could be and wanted to see if anyone else had experienced the issue.
    Hard for me to believe it's the wheels as they are basically the same size as factory/stock wheels and the issue doesn't occur in regular everyday use only after driving for a while on highway.
    Here's the comparison on the wheels:
    XD Enduro Size 17" x 9", Offset -6, Backspacing 4.76"
    TRD Sport Alloy Wheels Size 17" x 7.5", Offset +30 mm, Backspacing 5.5"
    Never drove truck with factory rims. It went straight from dealer to get new rims on.
    Last night when i got home and experienced the issue again I did all I could to inspect what was going on and could not see anything causing it. Nothing obviously out of shape or bent back by the wind...no visible marks anywhere that I could see.
    Likely not a major problem but would be nice to identify so I know wha going on after a long drive at high speeds.
  7. Sep 22, 2014 at 4:12 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    This is most likely the problem. Take 'em off, problem solved...
    David
  8. Sep 22, 2014 at 4:29 PM
    sfbbqguy
    Bay Area, CA
    '14 Dbl Cab 4x4 LB
    Makes sense. Off with them.
  9. Sep 22, 2014 at 6:16 PM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    It's your wheels. You change the backspacing, you might rub the flaps, fact of life.
  10. Sep 22, 2014 at 6:33 PM
    Canazes9
    David
    Texas
    Run stock wheels w/ agressive 265/75r16 tires and they'll rub also - particularly after a long drive....
    David
  11. Sep 23, 2014 at 6:38 AM
    karmatp
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    I already do run 265/75's and I have lots of space and never rub on and off road, stock suspension also.
  12. Sep 23, 2014 at 9:49 AM
    Canazes9
    David
    Texas
    Worked like that for me for 25k miles. One day after driving 3+ hrs at interstate speeds I stopped for gas, backed to pump, it caught an rubbed. After it was grabbed by the tire and bent in some it started happening more frequently, then all the time.
    David
  13. Sep 23, 2014 at 9:56 AM
    FatTony415
    FatTony415 Well-Known Member
    Tony
    San Francisco, CA
    '20 DCSB 4x4 TRD Off Road
    Stock for now
    ^ This. I had the same problem. Four screws and you're done.
