Front tires squeak during sharp turns / quick turns
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spansfelder, Oct 30, 2015.
  1. Oct 30, 2015 at 9:42 AM
    Spansfelder
    Spansfelder [OP] Well-Known Member
    Austin, TX / Germany
    05 4WD
    Gentleman,
    I need to clarify something which is driving me nuts at the moment.
    The facts:
    2005 Tacoma 4WD (TRD Sport) with manual gearbox, 6” lift on 35’s (Bridgestone Revo 2 / 315/70R17)
    So as far as I know, both differentials should be LSD, am I correct?
    Whenever I take a turn a little bit quicker/tighter, the front wheels squeak. That also results in the fronts wearing down faster.
    I could swear the truck didn’t do it when I bought it last year, but can’t guarantee it.
    So my front tires are almost done and the backs look almost like the day I got them. The tire wear is even.
    The question now, is it normal or am I getting paranoid?
  2. Oct 30, 2015 at 10:00 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Funny, this happens to me too. Started happening mid summer ( maybe it did it before and I didn't notice). Not all the time but occasionally when I make a sharp left turn I can hear something squeaking, and then when I let go from the turn everything is fine
  3. Oct 30, 2015 at 10:01 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    gee, maybe you need an alignment?
  4. Oct 30, 2015 at 10:02 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    35's rubbing at full lock maybe?
    Front diff is not LSD. It's open.
    That shouldn't affect wear though. Get your alignment checked.
  5. Oct 30, 2015 at 10:04 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Did you even read the first post?
  6. Oct 30, 2015 at 10:05 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    A said before, alignment. And maybe think about rotating your tires every so often...
  7. Oct 30, 2015 at 10:06 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Are you positive that you are not engaged in a drift when you hear this squeaking? One good way to find out is, the next time it happens, check and see if you are overcome with joy. If so, you are most likely drifting.
  8. Oct 30, 2015 at 10:08 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Sorry i was lunatic and miss this line of the post.o_O
  9. Oct 30, 2015 at 10:21 AM
    Spansfelder
    05 4WD
    Had the alignment checked a few month ago and they said it is fine. Wouldn't it show uneven tire wear if the alignment is off?
    Right now it only wears out the fronts way faster than the backs.
  10. Oct 30, 2015 at 10:32 AM
    Vassily28
    4WD not engaged
  11. Oct 30, 2015 at 12:57 PM
    Spansfelder
    05 4WD
    Correct, 4WD not engaged (which you shouldn't on the road anyways)!
