front tow point
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07NavyTaco, Aug 25, 2011.
  1. Aug 25, 2011 at 8:58 AM
    07NavyTaco
    07NavyTaco [OP] Well-Known Member
    Josh
    North Chicago
    07 SR5, short bed, 4x4, bilstein 5100s
    billy 5100s @ 1.75, black grill and lower valence, tinted windows
    ok, I live a few miles north of Chicago and there can be some pretty bad snow storms up here. I lived in Maine before I was transferred here and I pulled people out of the snow all the time. With winter approaching I'd live to a good strong tow point on the front of my truck but I don't have the cash for a big bad bumper. any cheaper suggestions?
  2. Aug 25, 2011 at 9:01 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    What's wrong with the hook under the passenger side of the OEM bumper?
  3. Aug 25, 2011 at 9:09 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    You have a hook since you have the OR package on your TX Pro. He doesn't have a hook.
    OP. Not sure if this type hook would work for you, but a cheap Smittybuilt hook fits in the two holes on the passenger side.
  4. Aug 25, 2011 at 9:14 AM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    ^^^X2 I got the same one for my truck from harbor frieght for $8!!!!! Works great I use it all the time.
  5. Aug 25, 2011 at 9:20 AM
    07NavyTaco
    Josh
    North Chicago
    I'm going to Tractor Supply this weekend to see what I can find. that EXACTLY what I need. thanks guys.
  6. Aug 25, 2011 at 9:22 AM
    07NavyTaco
    Josh
    North Chicago
    oh, I don't have a hook, I have a closed hoop.
  7. Aug 25, 2011 at 9:27 AM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    Yep, only the OR package comes with a highly-overpriced-if-bought-from-the-dealer-separately tow hook.
  8. Aug 25, 2011 at 9:33 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Just get a D-Ring shackle and put it in the closed hoop when you need it.
  9. Aug 25, 2011 at 9:35 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    this might work for light extraction but not a good idea to have it at such an angle...
  10. Aug 25, 2011 at 9:40 AM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    This may be true, but it's better than nothing at all.
    Also, it's worth mentioning, that its best to NOT pull vehicles out while driving in reverse if you can help it. The front tow point should be used when you need to be pulled out when situations require it.
  11. Aug 25, 2011 at 9:55 AM
    la0d0g
    running for the hills
    For crawling not hauling
    ^^ why is it bad to pull people out in reverse?
  12. Aug 25, 2011 at 10:08 AM
    Yoytoda
    Roland
    completely stock
    the way the diff is designed
    its better to use the drive side of the gear than the coast side although it shouldnt hurt anything
  13. Aug 25, 2011 at 10:23 AM
    pootermobile
    Florida
    It puts all the stress and weight on your weakest link(cv axles). That's how they break and, yes, that's how my old one broke:)
  14. Aug 25, 2011 at 10:26 AM
    horwitzs
    Seth
    Dayton, WA
    TX Pro
    I'm aware they don't all come with the hook, but it can be added. One of the forum members here is making them for a reasonable cost.
    My next suggestion would be this, for about $25:
  15. Aug 25, 2011 at 10:29 AM
    Yoytoda
    Roland
    completely stock
    the force on the cvs are the same in forward or reverse...
  16. Aug 25, 2011 at 10:30 AM
    Yoytoda
    Roland
    completely stock
    uhhh read the thread title lol
    unless you have a super duper edition with a front hitch
  17. Aug 25, 2011 at 10:33 AM
    ewa2fl
    ewa2fl Taco Jinx...
    Ed
    Wayne Co. 14516
    Tacoma DBLB V6 4x4
    Plati-Dip Badges & Removed a few, added D-rings in Bed, added recovery D-shackle, Added Front Recovery Hook, TRD Skid Plate-Rhinoed, added 2 mini tie downs, removed rear seat headrests.
    I put the Tractor supply hook on mine, but it's too damn close to the TRD Skid plate, thinking of switching it to the closed loop hook, then attached a D-Shackle, should I need to be towed out! Just need to find a 2 hole mountable Eyelet...
  18. Aug 25, 2011 at 10:39 AM
    pootermobile
    Florida
    Yes they have the same rotational force from the engine, but when pulling in reverse, the weight of whatever your pulling is pulling the front of the truck down. When pulling forward, it transfers weight from the front to the rear, putting more downward on the rear than the front could ever achieve. Which also gives you more traction pulling forward than reverse. There was a thread on this a while back.
  19. Aug 25, 2011 at 10:45 AM
    horwitzs
    Seth
    Dayton, WA
    TX Pro
    uhhh read the thread :jerkoff:
    Towing from rear instead has been discussed also.
  20. Aug 25, 2011 at 10:51 AM
    MartyMcfly
    MartyMcfly Time Traveler
    Rob
    Pahrump Nevada
    15' 4runner Limited 4wd
    see Build page for details.
    I suggest getting a couple D-shackles while you're at it.
    1) In case one breaks
    2) If you have to link two straps together. Looping straps together is fine, but getting them back apart after a pull is extremely difficult. Better to link them. EDIT: never mind. That's stupid. I'm an idiot.
