Front Turn Signal and Bumper Skirt Coming Loose
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Sep 24, 2015.
  1. Sep 24, 2015 at 3:43 PM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    1) The right front turn signal is fastened to the frame member by two Philips screws. Each screw goes through the turn signal into a white, cube-shaped, plastic clip. The clip is then pushed into a hole about 1/2 inch square. On my truck, the screws are tight into the clip but the lower clip is loose. See image.
    2) Also on the right side the lower bumper skirt is attached by one screw-clip on each side. One of them came loose and I need to replace it. See image.
    I can't find that clip in the repair manual. Can somebody please help?
  2. Sep 25, 2015 at 3:49 PM
    skeezix
    Colorado
    1998 Limited
    Here is an image of what I think I need:
  3. Sep 25, 2015 at 7:27 PM
    Maestro
    Maestro Well-Known Member
    The Master
    I think you are now officially the expert on this topic.
  4. Sep 27, 2015 at 9:47 AM
    skeezix
    Colorado
    1998 Limited
    Yeah, I think so... too many miles of washboard... :bikewhoops:
  5. Sep 27, 2015 at 10:03 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Take out that clip and stop by a body shop and ask for one they have tons of clips like that..as for the plastic square if it's loose put a zip tie thru it to tighten it up
  6. Sep 27, 2015 at 12:05 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
  7. Sep 30, 2015 at 1:04 PM
    skeezix
    Colorado
    1998 Limited
    I replaced one of the clips that hold the turn signal module to the bumper skirt. Actually there are 2 clips - one on top and one on the bottom.
    It made no difference - the turn signal still rattles. But it ain't a-comin' out... They won't come out of the bumper skirt on their own unless they are broken, and the dealer charges $2.85 apiece. The part number for those clips is: 90069-03035 but unless you break one, don't bother to replace them, just let the turn signal rattle.
  8. Sep 30, 2015 at 1:54 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    You might try taking out the housing, and put a thin foam strip around it, like the stuff for door jams they sell at hardware stores, to help it fit more snug. I suggested this to another member too. Idk if he tried it. I was going to as I had the same problem, but I since have removed them completely and put in leds in the headlight filler panel for turn signals.
  9. Sep 30, 2015 at 2:16 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    I went round and round with the dealer in an attempt to locate that screw/clip of which you speak, to no avail. They could not find it anywhere in the parts diagrams. I just went to ACE Hardware and bought a generic push-in style Christmas tree retainer. Done deal.
  10. Aug 28, 2016 at 2:07 AM
    rusorene
    rusorene Member
    rene
    it can be the same for a taco 2003 ?
  11. Aug 28, 2016 at 9:22 AM
    skeezix
    Colorado
    1998 Limited
    I don't know.
