Front Turn Signal Question
Discussion in 'Lighting' started by goufcustom, Jan 10, 2012.
  1. Jan 10, 2012 at 4:58 AM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2006 4x4 TRD Off Road DC SR5
    Bed Topper, Diff Breather, aFe Cold Air Intake, Satoshi Grill, Moved Horns, Oil Catch Can, Tailgate Lock, Husky Mud Flaps, H4 65/70W Bulbs, Lower Grill Mesh, TRD Skid Plate, LEDs in the bed, LEDs behind the grill for accent lighting, Parking lights as turn signals, LED turn signals and reverse lights, 5100s up front, eibachs up front, SS extended brake lines all around, 1.5" AAL in the rear, Relentless Fab U-Bolt Flip Kit, ICON Progressive AAL, TRD Wheel Center Caps, HomeLink, Heated Driver Seat, Hella 500 FF Driving Lights, BAMF Diff Skid, BAMF LCA Skids, BAMF Rock Sliders w/ KickOut.
    I have a 2006 Tacoma, when I am driving mid morning and early evening I put my lights in the middle position, so the dash lights up but my headlights dont come on. This is what I want for the 30 mins or so until it gets to dark and I turn on my headlights. I thought that on the Tacoma that the two front turn signal lights were supposed to be constant on as "marker" lights in this scenario? And then flash when using them for turning. Is this a 2009+ thing or is there a fuse blown, or am I just crazy?
    My turn signal lights all around work, and so do all my other lights, I just thought that the turn signal lights in the front were always on when the lights were on and then just blinked on one side when you were using them to signal a turn.
  2. Jan 10, 2012 at 5:05 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Only the corner lights come on unless you have DTRL.
  3. Jan 10, 2012 at 5:08 AM
    goufcustom
    MD
    So if you have DTRL the front turn signals are your front running lights? I thought DTRL meant you had your front headlights on? Atleast that was how is was on my Pontiac... Sorry for the dumb confusion, I feel like it is Monday. :eek:
  4. Jan 10, 2012 at 5:11 AM
    jtav2002
    Josh
    Reading, PA
    Yes, different cars use different DTRL setups. I used to have a Grand Am back in the day which uses the headlights at lower power. With the Tacoma, its the turn signal lights. Its an easy mod to add them for trucks not equipped with them.
  5. Jan 10, 2012 at 5:12 AM
    goufcustom
    MD
    Ok cool, thanks, I may do the mod when it gets warmer out, I have it bookmarked somewhere, and a search will find it too. Wiring when it is below freezing is just not fun...
