front vertical orange light?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Nov 18, 2010.
  1. Nov 18, 2010 at 2:50 PM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    I have seen people driving around with the front vertical orange lights ON in their taco. These only come on when I use a blinker....how do you get these to turn on and stay on? (The lights closest to the grille)
  2. Nov 18, 2010 at 2:52 PM
    jandrews
    '09 FourDubDee TRD OR
    Daytime running lights. It's a port-installed option. IIRC there's a wiring mod you can do to enable it in non-equipped tacos.
  3. Nov 18, 2010 at 2:54 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Orange lights in front, will be illegal in California, except for blinkers.
    Take care
    vbibi:(
  4. Nov 18, 2010 at 2:54 PM
    sooner02r1
    sooner02r1 Well-Known Member
    I dunno, mine came that way. It's an 08. Maybe a year-model difference?
  5. Nov 18, 2010 at 2:55 PM
    TOYOTA 09
    Maine
    mine is an 09!
  6. Nov 18, 2010 at 3:01 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Only 09-11 have the DRL's from the factory.
  7. Nov 18, 2010 at 3:04 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, and before you go wiring yours up, make sure you read all the threads on people who melted their lens because of that bulb being on full time. It's an intermittent problem but if yours aren't on all the time it might not be a bad option to miss out on.
  8. Nov 18, 2010 at 3:05 PM
    jandrews
    Meh, no big deal. That lense should be removed when you do the BHLM anyway.
  9. Nov 18, 2010 at 3:05 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    They are the DTRL's that are equipped on certain trucks. I bought the DTRL relay and installed it myself.
  10. Nov 18, 2010 at 3:21 PM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    doubt it, ive seen plenty of chevys driving around that come like that factory
  11. Nov 18, 2010 at 3:28 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My 07 came with the DRL's. They were listed under optional equipment on the window sticker.
  12. Nov 18, 2010 at 3:30 PM
    Pugga
    Massachusetts
    I know, just figured I'd give him the full disclosure. Seems only a handful of people have had an issue with it. I put that lens back in when I did the BHLM. I did mine white though so the orange tinted lens kind of broke up the white.
  13. Nov 18, 2010 at 3:41 PM
    09638 SCRAPER
    oahu,hawaii
    11 trd sport sr5 prerunner
    2% tint, 20% entire windshield tint, led bulbs, hids, debadged, grey plate covers, shaved antenna, alpine in dash, rockford t2 and amps, rockford highs and mids, 35x12.50x20 toyo mt's, 20x12 fuel octane's deep, 1.5 inch wheel spacers, camburg UCA's, 6" lift w/4" blocks & AAL, 3" body lift, open hood scoop, BHLM, painted emblem, K&N filters, weather tech mats. Next Mod: resevoir rear shocks, Vinyl camo wrap when I'm bored of the grey...
    they do look sick but they also burn your headlights lens. unless you remove them while doing bhlm. what I did was replace the bulbs with 20-led orange bulb thats gives off zero heat and look even brighter than the regular halogen bulb. it also takes away the "orange-glow" that you see in the reflector when the trucks not running, it looks a lot better all clear until you turn it on. thats what you should do.
    you can either wire it yourself or take it to the dealer and have them turn it on, costs 40 dollars if I recall correctly.
  14. Nov 18, 2010 at 3:42 PM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    It only depends on the model. My 08 Sport came with them. I am pretty sure they have had them since the 2nd Gens came out...but I could be wrong.
  15. Nov 18, 2010 at 3:47 PM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    All you have to do is buy some wire. split the green wire from the amber lights on the outside of the lights. Hook up the wire up to the green wire and run and jam it on the the wire 3rd hole on the blinker light. It takes about $1 and 5 min for each light.
  16. Nov 18, 2010 at 4:08 PM
    cactuscorn
    cactuscorn Another FNG
    Rapid City, South Dakota
    2019 Cement TRD OR AT DCLB w/JBL Premium Package
    Ironman Stage 2 FCP 3" lift kit, Ironman skid plate kit, C4 Fab Hybrid front bumper and frame supports, C4 Fab sliders, Smittybuilt X2O 10k lb winch, Diode Dynamics Pro fogs, Baja Designs Sport fogs, Falken Rubitrek AT's, Midland Micro MXT275 GMRS radio, Victory 4x4 hood hinge antenna mount, ARE MX shell, 12 Volt Solutions remote starter w/ phone app module, Overland Equipped aux power tray/Blue Sea 12 circut ST blade fuse block w/ 187 series 100a circut breaker, OEM bedmat and floor mats, Hooke Road tailgate cover, JDM ASTAR 800 lumen LED reverse bulbs, iOttie wireless phone charger, blue LED dome light, back seat dog bed and rear seat12v/USB ports, Ironman diff breather, ac drain mod,, tons of rad recovery equipment and every cubbyhole filled with crap. On order: Method MR 316 wheels and 285/70R/17 BFG KO2's.
    my dtrl's were a $40 factory installed option. i wanted em anyway but was somewhat floored when i noticed the ambers rather than the headlights were used. very odd. i hear they are easier to see by oncommin traffic compared to clears but i just wasnt prepared for the diff. oh well.
  17. Nov 18, 2010 at 4:16 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    08White, you are right. My 05 came with them...
  18. Nov 18, 2010 at 4:19 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    I got blue ones
  19. Nov 18, 2010 at 10:45 PM
    09638
    09638 SCRAPER
    oahu,hawaii
    where im from thats just saying please pull me over
  20. Nov 18, 2010 at 10:49 PM
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    Standard in Canada...I like 'em, gives the truck a kinda mean look.
