front wheel adjustment nut
Discussion in '2nd Gen. Tacomas (2005-2015)' started by esse10, Jan 25, 2012.
  1. Jan 25, 2012 at 3:25 PM
    esse10
    esse10 [OP] Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Hello fellow TACOMAWORLD friends. Does anybod know how to remove the front Bearings adjustment nut that has four holes? what special tool do I need? or does that just get done when the machine shop presses my new bearing into my old hub? I included a picture of my old bearings with the silver nut in the middle with 4 holes. I read somewhere's that the nut is torqued to 200 fb-OMG! Any help would be appreciated.
    this came off a 2005 tacoma prerunner 2 wheel drive front bearing.
    thanks, julina from rosenberg.
  2. Jan 25, 2012 at 5:46 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    That looks different then my 4x4 bearings so I won't be much of a help. You have a front wheel adjusting nut I'm not familiar with.
    See the PDF's I attached for some help. Look up the Toyota "SST" part number and see what specialty tool Toyota says it is and then see if something similar is available on the market that will do the same job.
    When you do get the nut off take it to a shop to get the old pressed out and the new pressed in. I took mine to Napa and they were done in a couple hours for less then $20 per side (labor only - i supplied parts). Just be sure to get the right bearing for a pre-runner....and do not forget to get new seals and pack the bearing with good bearing grease.
    Good luck & let us know how you make out.
  3. Jan 25, 2012 at 5:55 PM
    XXXX
    sKiP
    05 Prius
  4. Jan 25, 2012 at 5:56 PM
    esse10
    Texas
    hey thanks I will check out the pdf files.....
  5. Jan 25, 2012 at 6:05 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You can also buy piece of 1/4 inch steel. Drill 5 holes in it. 4 holes smaller, then install 4 bolts that will fit in small holes. Center bolt needs to be bigger thats what you use torque wrench on it.
  6. Jan 25, 2012 at 7:01 PM
    esse10
    Texas
    Sounds like a good Idea, but won't the center bolt turn when you try to adjust or tighten? 200 foot pounds is a lot of torque, did you do this already? do you have pictures of what exactly you're talking about?
    better then paying toyota 80 bucks for a stupid tool hah?
    thanks for your help man......
  7. Jan 25, 2012 at 7:05 PM
    BlueT
    NorthEast
    Yep but for my LC which uses 3 point nut instead of 4 point. :D Its crude but it worked and costed me like $20 in scrap metal and bolts. I will get pic tomorrow. Too cold to open garage man
  8. Jan 25, 2012 at 7:11 PM
    esse10
    Texas
    LOL , :D it's 60 degree's down here in TEXAS. Okay I can wait for the pictures later. I kinda get the Ideal I will start searching tomorrow for
    1/4 inch steel, high grade bolts and stuff.........
    thanks man.
  9. Jan 25, 2012 at 7:22 PM
    BlueT
    NorthEast
    Its easy. Take cardboard and trace 4 holes on it. Draw lines to criss cross them thats your center bolt. You need to find 4 small bolts that will fit in the holes in nut. Your center bolt should be as big as you can get. You install center one backwards so when you torquing it will try to tighten center bolt. Worst come to worst glue the sucker to metal or ask somebody to put few welds on it. I make my SS tools. Dont have money to buy stuff so I need to be creative :D
  10. Jan 25, 2012 at 7:31 PM
    esse10
    Texas
    COOL man, that sounds like it will work. Now I feel like tom hanks in that movie CASTAWAY when he found the piece of hard plastic to make the sail with........" THIS COULD WORK! " LOL thanks for u help fellow tacomaworld mate. I will be in the hunt for this hardware tomorrow.:D
  11. Jan 26, 2012 at 11:28 AM
    esse10
    Texas
    Hel fellow TACOMAWOLD members, just an fyi to let you know I found this tool on the internet and seems like it would work. It's only 10 bucks on AMAZON, but was wondering if anybody else already ordered this particular one from amazon only to find out it's the wrong tool. The picture shows to be the correct one, the reviews online show to be the right one. heck at 10 bucks I am willing to order it just to find out...here is the link . let me know what you'll think.
    http://www.wilmarcorp.com/item.aspx
  12. Jan 26, 2012 at 11:59 AM
    XXXX
    sKiP
    05 Prius
    The link just goes the the website...not a specific tool. try grabbing and dropping the picture of it into your TW reply.
  13. Jan 26, 2012 at 12:50 PM
    esse10
    Texas
  14. Jan 27, 2012 at 5:11 PM
    esse10
    Texas
    Hey you never got back to me on your thoughts about that tool, what do you think xxxx?
  15. Jan 27, 2012 at 6:39 PM
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    Just a fyi, but I tried to rent the socket from Advanced, Napa, and another store and no one had it. The universal kit they rent did not have it either. I had to take both bearings to my stealership and they took the nut off for $50.
    Good luck.
  16. Feb 1, 2012 at 4:55 PM
    esse10
    Texas
    I really appreciate peoples help here on this forum. I just want to update my finding so that maybe it can help out the next guy having the same problem. I got my locknut socket today and it's exactly the correct fit to re-tighten the hub bearing. Hope this helps out the next person with the same problem and same truck; 2005 Tacoma V6 4.0 prerunner , two wheel drive , 4 door double cab. I bought it in Amazon for 10 bucks + shipping.
    Just go to Amazon.com and type W1272 socket in the search box. Here is a picture of it. Let's just hope it holds up to 200 foot pounds of torque ...LOL
    REDdawn6, gm6095 and chinorx3 like this.
  17. Feb 1, 2012 at 5:10 PM
    XXXX
    sKiP
    05 Prius
    Glad to see you found it. I was out of town for a 3 day weekend.
    Have you tried it yet? If it works and you have no issues be sure to let everyone know so they can save themselves some cash.
  18. Feb 1, 2012 at 6:56 PM
    esse10
    Texas
    Well I'm sure it will work cause I already measureup the socket to the nut and it fits lilke a glove it's just a matter of now taking my old hub to the machine shop so they can press my new bearing and I'll torque it in a vice. Should be done this weekend I will keep you'll posted though. Too bad There isn't a MFG out there that sells the hub and bearings already pressed in, easier swapt like that. I checked all around the internet and even the dealer and nobody has it for the 2005 V6 prerunner. TA TA FOR NOW!:D
  19. Feb 2, 2012 at 4:11 AM
    XXXX
    sKiP
    05 Prius
    They don't make them for the 4x4's either. If they did the cost would most likely be huge.
    Good luck.
    You should take a bunch of pics and do a quick write up. I'm pretty sure there isn't one for all you 2wd guys. All you would have to cover is that nut cause the 4x guys have a write up for the rest.
  20. Feb 2, 2012 at 9:13 AM
    esse10
    Texas
    Sounds like a good Idea I'll see what I can do I'am not really good with diy writing. I need to find out how to torque the silver nut , I wonder if it's like regular bearing where you go a little pass over and then come back a little or just a one time 200 footpound tight and leave there????????? :confused:
