Front Wheel Alignment for 4WD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chevylu, Sep 30, 2011.
  1. Sep 30, 2011 at 7:03 PM
    chevylu
    chevylu [OP] New Member
    Are there any gurus out there who know how to decipher the Vehicle Models in the online 2005/2006 Repair Manual that deals with Front Wheel Alignment for 4WD.
    For example, my tire size is P245/75R16 but I don’t know which spec applies to my vehicle; that is, I don't know how to determine my vehicle model.
    In addition, can someone explain what page SP-12 is attempting to illustrate with regard to turning the cams. It would be nice to know what an alignment tech is up to down there.
  2. Sep 30, 2011 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Best thing is to get slightly posative toe, for example; .05*. A little posative camber, .2* (non lifted applications), and about 2.3* Caster. 2.1* is fine for a non lifted truck.
  3. Oct 1, 2011 at 6:00 AM
    chevylu
    I finally found my Tacoma's Vehicle Model #. It's located on the label inside the driver's door. In my case it is TRN240L-TRMDKA.
    According to the 05/06 online manual, the Camber should be .58* and the Caster should be 1.73* See: http://i.minus.com/ibfdfStC9eO0IS.png
    According the Chilton, the Camber should be 1.62* and the Caster should be .3* See: http://i.minus.com/irFKi2kTi1Ptq.png
    Who ya gonna believe?
