front wheel bearing broke after alignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by laith, Nov 28, 2011.
  1. Nov 28, 2011 at 6:20 PM
    laith
    laith [OP] New Member
    kalispell
    06 Tacoma off road shortbox
    I got new tires and an alignment from the Toyota dealership on a 4-wheel drive 06 Tacoma and within 50 miles of asphalt I had a broken front left wheel bearing. Is that just random bad luck or coincidence :confused:
  2. Nov 28, 2011 at 6:31 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    sounds fishy. they probably didnt check your front and before doing the alignment. get your spec sheet. might be able to get them to pay for it. Or if you pay for a new wheelbearing, they do the alignment for free.
  3. Nov 28, 2011 at 6:32 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    When you broke do you mean it got noisy and then sloppy or it actually broke and came off the truck ???
  4. Nov 29, 2011 at 7:25 AM
    laith
    kalispell
    It was a super noisy metal on metal grinding sound, not broke off the truck. They gave me a free alignment after the new bearing was on, so they took responsibility for some of the blame, but not the expensive part. Since they took part of the blame im suspecious they are more at fault then they are leading on but i cant prove it. The spec sheet indicated the rotor was rubbing on the backing plate.
  5. Nov 29, 2011 at 7:29 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I can't see how an alignment would cause a wheel bearing fail, no matter what they did wrong.
    I say bad luck coincidence.
  6. Nov 29, 2011 at 1:17 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    Correct. There is no adjustment that would cause this laith.
    The reason they took "some of the blame" is this was bad when they did the alignment and so they gave you another alignment which they should have done anyway. They should have caught it before but like anything else....................................
  7. Nov 29, 2011 at 8:03 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    1. they should ALWAYS, 100% of the time, do a front end check before alignment.
    2. Rotor rubbing on backing plate...? holy fuck. that wheel bearing woud have to have been TOASTED
    3. glad they did a free alignment after. their mistake for not catching that wheel bearing in the first place
    4. do not return to that dealer
