Front Wheel Bearing Gone Bad....FYI
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PPower05, May 29, 2013.
  1. May 29, 2013 at 4:45 AM
    PPower05
    PPower05 [OP] Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Hi all,
    Know I have seen a lot of this going around the fourms, just wanted to share my experance... Noticed a noise in my Left Front (Drivers Side) Front wheel @ 30,000 miles, thought it was probably a tire, had them rotated, noise seemed to go away, execept really cold days.... The noise was most evident between the speeds of 65-70 mph. Fast forward to 49000 miles, and it is a loud noise that doesn't go away ever, and almost starts a vibration in the truck... For all those with less than honest dealers, BOTH of my local stealerships stated that wheel bearings fall under your powertrain warranty..... Don't let them tell you otherwise. Went to my local shop (trusted, decent prices) to diagnose the problem, nearly 300 on labor alone! If your truck is less than 5 years old and has less than 60000 miles, would strongly suggest you get this issue checked. I am going to Toyota on Friday to have the bearing replaced.
    On another off handed note, have seen some complain of the stock tires put on the Tacoma, have gotten nearly 50000 miles out of them, probably still good for another 10000!
  2. May 29, 2013 at 5:00 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Confused by that statement, but glad you are going in for the fix, sometimes they just freeze and snap the spindle, usually, they give plenty of warning (noise) before they go..
    So, is it a warranty issue or part of an extended powertrain warranty?
  3. May 29, 2013 at 5:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Toyota Standard power train warranty is 5 years or 60,000 miles, whichever comes first.
  4. May 29, 2013 at 5:34 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Thanks for the tip, will get it looked into. Mine has around 40k now.
