Front wheel bearing/knuckle assy.
Discussion in '1st Gen. Tacomas (1995-2004)' started by awkdeere, Dec 19, 2020.
  1. Dec 19, 2020 at 6:43 AM
    awkdeere
    awkdeere [OP] Member
    Tony
    2003 Tacoma Prerunner
    None
    Hello, does anyone know if a 4x4 front wheel bearing/knuckle assy. will fit a 2 wheel drive pre-runner, so I won't have to press the bearing in/out ? Will be able to simply buy another hub & bolt on. Thanks
  2. Dec 19, 2020 at 6:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The spindle itself is identical, so is the wheel bearing.
    But the hub axle is different as the 4x4 variant supports the axle that comes from the front diff.
    There's also the fact that some have abs and others do not.
    Black DOG Lila likes this.
  3. Dec 19, 2020 at 10:39 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  4. Dec 19, 2020 at 11:14 AM
    awkdeere
    Tony
    None
    Hey thanks, ... but I'm wanting to put ABS 4x4 knuckles on my prerunner to allow for easier future wheel bearing replacements.
  5. Dec 19, 2020 at 11:17 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well if you understood what I said above...
    You can use 4x4 spindles, what you are referring to as knuckles (yes Toyota calls them steering knuckles as well), you can use them once you replace the hub axle with the appropriate component. The hub axles are different as a Prerunner is 'capped off', and 4x4 components have a hub axle in which the cv axle slides into.
    When you say easier wheel bearing replacement, I think you meant, less downtime on your vehicle by having a set done for you and waiting install?
    Replacing the wheel bearings on Prerunner spindles and 4x4 spindles are no different from each other.
    Slight changes in verbiage can altogether change the meaning of a statement entirely.
    Wyoming09 likes this.
  6. Dec 19, 2020 at 1:43 PM
    awkdeere
    Tony
    None
    To my knowledge, a spindle/hub is what attaches to the wheel; however, a knuckle is the iron casting located between the upper & lower ball joints. My question was somewhat answered as to whether a 4x4 “knuckle” would fit on a prerunner truck (mine has ABS, yours did not). It looks to be in the same location, just not sure about direct plug in. Wheel bearing servicing is most definitely different. A prerunner used a pressed-in non serviceable sealed bearing which requires periodic replacing by removal of the “knuckle” assy. , and either having a large press or taking it to a repair facility that does. ( Toyota wants $300 + to do this ). On the other hand, a 4x4 “knuckle” assy. uses 4 easily accessible bolts to hold on a serviceable hub (spindle) which according to you tube, can be replaced without “knuckle removal” or pressing requirements, …. by me. These replacement bolt on hubs can be purchased all day long. Overall, $700 vs $3oo and being able to do it myself in less than 3 hours for both sides is a no brainer. Just need to make the 1st initial investment in 4x4 “knuckles”. Information was appreciated, thanks ….. Tony
  7. Dec 19, 2020 at 1:48 PM
    awkdeere
    Tony
    None
    And yes, there are 4x4 knuckles that have ABS. Verified by pics and Toyota service/parts departments.
  8. Dec 19, 2020 at 1:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If the servicing between the two is easier on one than the other, than that's great to hear!
    You don't need to let me know that they're the same; that's what I have been trying to tell you.
    The spindles listed above aren't mine, they are a set that are available for purchase.
    Prerunner and 4x4 spindles are both available with and without abs, yes I know this. You simply confirmed it.
    Just trying to offer information based on how they're the same, and how they're different.
  9. Dec 19, 2020 at 1:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Timmah! Is really good with this stuff, he has tons of videos online for DIYers
  10. Dec 19, 2020 at 2:01 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    @awkdeere
    2nd gen 4wd front wheel bearings are the easy bolt on.
    1st gen 4wd require 40 Ton pressing
    Wyoming09, Kwikvette and Mongoose like this.
  11. Dec 19, 2020 at 4:40 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Hey. I have 1 good 4wd abs spindle. Driver side....the passenger side is fucken toast. Lol
    Burnt toast. Like catch my kitchen on fire toast
  12. Dec 19, 2020 at 5:16 PM
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
    Winner, this is the answer, Gen2 has 4 bolts for bearing assembly, Gen1 need to press in and out.
    Kwikvette likes this.
  13. Dec 19, 2020 at 5:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I knew 1st gen spindles required pressing regardless if they're 4x4 or Prerunner; I just wasn't sure what the OP meant when he corrected me.
    They're the same for Prerunner and 4x4 with the exception of the axle hub.
  14. Dec 19, 2020 at 5:23 PM
    Black DOG Lila
    Virginia
    The difference between YouTubers and real life Doers always shows.
    Glad to see you out of jail so soon :thumbsup:
    :hattip:
    Kwikvette[QUOTED] likes this.
  15. Dec 19, 2020 at 5:23 PM
    awkdeere
    Tony
    None
    I'm sorry, ... still learning my new used Tacoma ..... you guys are correct about the 1st generation but I looked and saw a you tube video of a girl removing this hub as an assy. I just need now to find complete 1st gen hub to install. Anyone know where I can get this ? Thanks and I apologize again for my mistake. Tony
  16. Dec 19, 2020 at 5:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Abeyancer recently found new ones for manual hubs, maybe that source will provide some for Prerunners.
    Most of us use Rockauto unless it's an important part like a lower ball joint, then we suggest OEM.
  17. Dec 19, 2020 at 5:26 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    The ones I found came off of ebay
  18. Dec 19, 2020 at 5:42 PM
    Black DOG Lila
    Virginia
    @awkdeere
    This may help you know what you are looking for and what it's called. :thumbsup:
  19. Dec 20, 2020 at 2:57 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just a drier Climate !!
