Front wheel bearing orientation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jas521, Sep 7, 2025 at 8:14 PM.
  1. Sep 7, 2025 at 8:14 PM
    Jas521
    Jas521 [OP] New Member
    Sunday
    03 Tacoma 4x4
    Does anyone know which way to install a Koyo front wheel bearing on an 03 4x4 Tacoma? It's discussed in a thread but never got answered... I'm not detecting much magnetism on either side, one side is all metal and the other has a black plastic ring. My mechanic put the metal side in but I want to make sure it's correct.
    Black97v6MT likes this.
  2. Sep 7, 2025 at 11:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Your image is not loading.
  3. Sep 8, 2025 at 12:56 AM
    Jas521
    Sunday
    03 Tacoma 4x4
    Thanks, I think I fixed it.
  4. Sep 8, 2025 at 12:58 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    @zippsub9 might be able to point you in the right direction.
    I'm pretty sure timmy the toolman has a detailed video on changing the front wheel bearings as well. He usually includes details like orientation, etc.. might be worth watching his video in the meantime.
  5. Sep 8, 2025 at 4:13 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Ohhhh Yeah
    Make sure magnet side goes in the correct direction
    Big Time re work job if ABS lite comes on after incorrect install
    I’m sure there are some markings on said bearing(s) to orientate correctly
    Or
    Once determined what side of bearing has magnet with paper clip
    Make sure that M side faces ABS sensor
  6. Sep 8, 2025 at 4:14 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
    Jas521[OP] and ControlCar like this.
  7. Sep 8, 2025 at 5:31 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Please elaborate, there is no magnet in the first gen bearings. The passive sensor utilizes the pulse off the tone ring of the ABS ring and has nothing at all to do with the bearing whatsoever.
    I always protect the softer black bearing seal behind the hub so it never gets exposed to elements. The metallic silver seal side I put towards the inside of the knuckle. I’ve been building these since 2014 for both ABS and non-ABS setups.
    I believe the magnet you are thinking of is what resides inside the sensor to open and close the circuit for ABS and not in the bearing.
    There are probably varying opinions on orientation but this was the best way to protect the sealed bearing I found and never had any ABS issues. The tone rings are prone to damage easily which will cause issues if the sharp edges aren’t protected on the outer surface.
  8. Sep 8, 2025 at 5:33 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    The second and third Gen bearings use an embedded hall affect sensor incorporated into the bearing.
    Area51Runner likes this.
  9. Sep 8, 2025 at 5:38 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Supporting the inner race when pushing in the hub is probably the most important step. If the race bends or mangles the seal then that bearing is now exposed to elements and early failure. Other than that, side preload is the other main killer. Either ADD CV nut at 173 lb/ft or 203lb/ft on manual lock nut on 4x4 or PreRunner.
  10. Sep 8, 2025 at 7:04 PM
    ControlCar
    Steven
    Sugar Land TX
    Sorry assumed magnet!
    zippsub9 likes this.
  11. Sep 8, 2025 at 9:58 PM
    Jas521
    Sunday
    03 Tacoma 4x4
    I watched that video and he puts it in the opposite way, with the tone ring facing out. This led to a big debate with my mechanic who insisted on doing it the other way. In the video timmy the toolman is working on a 3rd gen 4runner.
  12. Sep 8, 2025 at 10:15 PM
    Jas521
    Sunday
    03 Tacoma 4x4
    Thanks zippsub9 for all the info! Did a lot of searching and couldn't find it anywhere else. This was my first experience with TW and y'all came through, appreciate it!
  13. Sep 8, 2025 at 10:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The spindle and bearings on the 3rd gen 4runners and the 6 lug Tacoma's are the same. If I am reading correctly what @zippsub9 is saying, the bearing can be used in either direction.
    You may not want to hear this, but I think you need to use them as they are now. Unfortunately you cannot simply reorient the currently installed bearing as removing them will surely destroy them.
    zippsub9 and Area51Runner like this.
  14. Sep 9, 2025 at 9:02 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Yes, @Digiratus is correct. The bearing can be installed in either orientation. There is no one way universal. I install as pictured for the reasons I mentioned above, but that is for protection of the seals as I see them. The tone ring can only be installed one way. It is a separate component that gets stacked onto the bearing and locked into orientation as part of the preload stack.
    @Jas521 the tone ring is not part
    of the bearing on the first gen Tacoma or 3rd gen 4Runner. It is a separate piece. Tim the Toolman video does show an opposite orientation install. It will work either way, but have never found or had any documentation from Toyota for orientation otherwise. I keep the “weak” side protected behind the hub. It is my opinion and technique alone. The seals on both sides are thin and easy to deform if not careful. The bearing install is one time shot. A brand new bearing cannot be removed and reinstalled. They are destroyed upon removal. It is a sealed unit from JTEKT/KOYO and regardless of any race re-stack the seals are compromised.
