Front wheel bearing part #
Discussion in '1st Gen. Tacomas (1995-2004)' started by Reeso, Aug 20, 2015.
  1. Aug 20, 2015 at 4:29 AM
    Reeso
    Reeso [OP] Member
    Mauricio
    03 Tacoma v6 SR5 4x4
    Hey guys what's up, new to the forum just got my Tacoma about 8 months ago! Love it but have a question hoping someone could help.
    I'm wondering if anybody could share some insight on what the correct part number is for the front wheel bearing. It's an 03 Tacoma v6 4x4 SR5 automatic. I've looked online and rockauto has about 5 different numbers and range from $35-$90. Just want to make sure I get the correct one.
    Having to replace it myself after I got quoted $490 to fix the front passenger wheel bearing at the shop!
  2. Aug 20, 2015 at 5:00 AM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Its a pain in the ass to do I believe.... I would take it apart and to a shop to have it pressed
  3. Aug 20, 2015 at 5:56 AM
    Reeso
    Reeso [OP] Member
    Mauricio
    Yes that's what I'm gonna have to do. we have a 50 ton press at our weld shop but I've never pressed in a bearing before and kind of afraid I'll mess up something. I know people say it takes a 50 to press that's a lot of force
  4. Aug 20, 2015 at 5:58 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    The TGP# for the bearing is 9036954002
    http://parts.camelbacktoyota.com/pa...siteid=214329&vehicleid=78972&diagram=8510205
    As stated previously, the bearing is a PITA to press out and in. Many people pull the spindles and take them to a dealership to have the pressing done as they are usually best setup for it. There are also a bunch of other parts that are best to have new on hand especially if you have ABS:
    8 hub assembly seal 9031669001
    9 hub assembly seal 9031295001
    10 Snap Ring 9052199114
    12 ABS rotor 4351535010
    13 spacer 4352435010
  5. Aug 20, 2015 at 6:15 AM
    Reeso
    Reeso [OP] Member
    Mauricio
    Ok I'll probably end up taking the spindle to Toyota then. My ABS doesn't work so should I still replace all the ABS parts as well?
  6. Aug 20, 2015 at 6:29 AM
    tomtom
    The Desert SW
    2012 FJ
    My understanding is the ABS rotor is a consumable. They typically cut it off and I don't think it is considered re-usable if it could even be pressed off.
  7. Aug 20, 2015 at 8:43 AM
    Reeso
    Reeso [OP] Member
    Mauricio
    Oh I gotcha now. Good to know thank you!
  8. Aug 20, 2015 at 9:30 AM
    Reeso
    Reeso [OP] Member
    Mauricio
    Gonna get ball joints and replace while I'm at it but I'm confused which ones to get because the description says there are ball joints for "w/pre-runner" and "w/o pre-runner"? Mine is 4wd with the rear locker so is that w/o pre-runner?
  9. Aug 20, 2015 at 1:40 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Ya, prerunner is 2wd
  10. Aug 20, 2015 at 1:55 PM
    tomtom
    The Desert SW
    2012 FJ
  11. Aug 20, 2015 at 8:03 PM
    Reeso
    Reeso [OP] Member
    Mauricio
    Awesome just ordered them appreciate all the help!
