Front Wheel Bearing replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bradpace16, Jan 11, 2013.
  1. Jan 11, 2013 at 6:56 PM
    bradpace16
    bradpace16 [OP] Active Member
    Denver, CO
    06 Tacoma Crew
    Hey Guys,
    I am replacing a front wheel bearing assembly. I have done the other side before, easy job. This time, the machine shop messed up my hub when getting the bad bearing off. So they ordered me a new hub and bearing. I got them pressed together (all new parts) and now the hub wont slide onto the spindle all the way? Only gets about 2/3 way on? The old hub slides right on with no problem? Could I have gotten a flawed/wrong hub? Please Help..
  2. Jan 12, 2013 at 12:46 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    you mean the hub/bearing assembly won't slide INTO the knuckle all the way?
    Do you have the old bearing/hub? Do they appear identical?
  3. Jan 15, 2013 at 3:58 PM
    bradpace16
    Denver, CO
    06 Tacoma Crew
    Yes they are identical. I actually got the thing in. I was able to pull the thing on by tightening the CV nut.
