Front wheel bearing symptoms and noises?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Basin and Range Tacoma, May 6, 2018.
  1. May 6, 2018 at 5:47 PM
    Basin and Range Tacoma [OP] Member
    Jerry
    Salt Lake City Utah
    99 white Tacoma trd
    Allpro expos, toytec boss with SPC uca’s,Yukon 4:88’s, sliders and shell. 255/85/16 km2’s
    I have a strange noise coming from my front end. Sounds like I have tsl boggers on it but they are brand new km2’s. Second set of these tires, noise started here and there a month ago or so and has recently become worse. My suspicion is wheel bearing?
  2. May 6, 2018 at 7:48 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    could be.
    I started with same symptom and never have narrowed it down.
    Now it vibrates at high speed but still can't find it.
    An old man I know has the same on his '98 but much worse. I'm kind of waiting for his to blow apart to know the next direction.
    BTW, I changed my bearings. Weren't them.
  3. May 6, 2018 at 7:51 PM
    Jerry
    Salt Lake City Utah
    99 white Tacoma trd
    Mine seems to get a little better at high speeds as far as the noise. Truck drives and rides smoothe. Just has this awedul noise.
    Have you changed wheel bearings?
  4. May 6, 2018 at 7:53 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Yea, first thing I did was bearings. Vibration didn't start 'til later.
    I rebuilt my CVs, suspect needle but it doesn't go away in 4WD so I dunno.
  5. May 6, 2018 at 7:56 PM
    Jerry
    Salt Lake City Utah
    99 white Tacoma trd
    Right on. Thanks for the reply. I suppose it could be in the front diff. That’s all new. I’ll let ya know what I find.
  6. May 6, 2018 at 7:57 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Yea, it's what I'm afraid is gonna show it's face. Hope not. I've kept up maintenance and it's never been full of water......or shavings.
    Edit: Took off front drive shaft. No change.
  7. May 6, 2018 at 8:21 PM
    Jerry
    Salt Lake City Utah
    99 white Tacoma trd
    If it does turn out to be that, they are easy to pull out and I just re geared not long ago but I bought my front clam shell already set up so I am kinda questioning that. A bearing change isn’t to bad on those but still a pain.
  8. May 6, 2018 at 8:30 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  9. May 6, 2018 at 8:34 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Plus if you do rock it at 12 n 6 n get no movement. Spin the wheel as fast as you can as it can still be bad. If it makes any noise other then the brakes rubbing the rotor it is bad. It will be a low pitch hum. If thats the case replace them immediately as it is super bad to drive on bad wheel bearinngs. They must be pressed out and new ones pressed in
    Edit spin both driver and passenger, passenger usually fails first and as in my case was a good way to see the difference in noise when spinning the wheel. Mud terrains make it hard to spot at first
  10. May 6, 2018 at 8:41 PM
    Jerry
    Salt Lake City Utah
    99 white Tacoma trd
    Oh right on! I think they are smoked. The low pitch hum sounds familiar. Thank you very much dudes! I’ll keep y’all posted.
    Prayn4surf likes this.
  11. May 6, 2018 at 8:44 PM
    Prayn4surf
    Socal
    When they fail completely they can do a few things. Your wheel can fly off the truck and your truck slams on the ground. It can sieze and drag you to a screeching hault, or can get so hot it welds to your spindles. It would get really load to do these things, but gives you an idea of how important wheel bearings are
  12. May 6, 2018 at 8:49 PM
    Jerry
    Salt Lake City Utah
    99 white Tacoma trd
    Thank you! I do understand the importance. I have checked the 12 and 6 movement and have no movement, I do hear the low hum growl noise. On the road it sounds like my tires are cupped so bad and boggers. It’s a brand new set of km2’s 255’s my second set on the truck so I know it’s not the tires. It was also just aligned two weeks ago. I’ll get these bearings swapped out this weekend.
    Thanks again my man. I’ll let ya know the out come.
  13. May 7, 2018 at 6:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Feel free to use that video in your marketplace ad or anywhere else you may need it!
    05Taco4x4[QUOTED] likes this.
  14. May 7, 2018 at 8:13 AM
    05Taco4x4
    2TR-FE Enthusiast
    Right on, thanks
    EatSleepTacos[QUOTED] likes this.
  15. Sep 13, 2018 at 6:21 PM
    wee
    wee Well-Known Member
    I have same issue....What fixed your issue that is if you got it fixed....?
    Brian
