Front Wheel Bearings, Which is Best and Where to Buy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PMK, Jun 15, 2020.
  1. Jun 18, 2020 at 8:18 PM
    PMK
    PMK [OP] Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Yes, the special socket for a Prerunner is a 4 pin type setup.
    Thanks for those wonderful replies to help another Tacoma owner.
    Timkens it will be, coming from Rock Auto. If the seal surfaces can not be polished in the lathe, then it will be new hubs too.
    All the best, have fun and be safe.
  2. Jan 20, 2022 at 12:20 PM
    SpaceAntelope
    SpaceAntelope Member
  3. Jan 20, 2022 at 10:56 PM
    TacoTuesday1
    SD CA
    If you buy the bearing, what hubs are you putting them on?
    I currently have eBay hubs which are probably not as high quality or good as OEM
    am guessing the cheapest way to get an OEM hub is from the junkyard,
    but my last one (now gone) I feel like the bearing was seized onto it with rust from being many years old
    It's probably easier to start with a new hub (whether OEM or aftermarket) and simply press a new bearing onto it, without having to remove an old one.
    I suppose if OEM turns out to be an insane price for a new hub then at least finding a decent middle ground aftermarket part from a known name brand could suffice
  4. Jan 20, 2022 at 11:30 PM
    SpaceAntelope
    yea im looking for the full hub/bearing assembly. The OEM replacement at NAPA is double the cost of the aftermarket options on rock auto, just not sure what aftermarket brand is going to be the best quality?
  5. Jan 20, 2022 at 11:42 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
  6. Jan 21, 2022 at 12:02 AM
    TacoTuesday1
    SD CA
    why not just figure out what parts he uses/where he gets them and do it yourself
    the pictures show them as being all new
    so that obviously rules out the possibility of relying on used core hubs.
    When you pay someone else to assemble something else for you, you pay $300 for $100 in parts and $200 in labor to fund a business justified as being worth their time, which for a grown man is usually in private at least $50/hr.
    Same as paying your butler Jeeves to spoonfeed you Honey Bunches of Oats in the morning $300 per breakfast
    some people can, do, and only know that route
    clutch job DIY? $400
    pay a shop? $2k
    Some things, it can be unavoidable, if you don't have the facilities, experience, skills, tools, and so on. Collision repair, windshield replacement, painting, welding, etc.
    But replacing a car wheel bearing yourself is not fucking hard
  7. Jan 21, 2022 at 12:23 AM
    Superdave1.0
    SoCal
    Yeah I'm all about doing it yourself. If you have the tools and the space to do the work.
    All I recommended was where to buy the parts. As far as assembling the hub/bearings good luck. I work on several Tacomas a week, own a shop press, and I wouldn't attempt to assemble a hub/bearing on a Tacoma.
  8. Jan 21, 2022 at 10:46 AM
    SpaceAntelope
    thanks for the links. I really only want to do 1 side and 05Taco4x4 only sells as pairs. I am going to do the install myself which is why I want the pre-assembled hub/bearing combo (no bearing press or prior experience with that part of the job). Looks like the bluepits are almost the same cost for a single and use dorman hubs anyway. Wish RockAuto would disclose what bearings are actually used in the "OE" dormans they sell...
  9. Jan 21, 2022 at 11:57 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    I disassembled a Dorman gen 2 Tacoma wheel bearing assembly and there were no markings at all on the bearings. Unknown bearings but the hub said Dorman. I doubt that Rock Auto would know.
    burrito782 likes this.
  10. Jan 21, 2022 at 3:41 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Even if RockAuto disclosed it, I'd still be going straight to the source (Dorman) for verification.
