Front Wheel Bearings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coolreed, May 3, 2016.
  1. May 3, 2016 at 7:28 PM
    coolreed
    coolreed [OP] Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    Driving home from work and heard a faint grinding noise on my 2006 Prerunner. Knew immediately that I had a wheel bearing issue. So,...I rolled into the local Taco Stealership and asked the Service Dept. what it would cost to replace both wheel bearings (hubs). They quoted me approx. $1000.00. $500 Labor and $500 for parts. I stated no way,..I will do it myself. Mileage on my Taco was about 118k.
    So,..I ordered two wheel hub/bearing assemblies from a Toyota parts supplier in Florida. Searched You Tube for tips and installed them myself for about $350.00. That was for both sides because you should change them in pairs in my opinion. Took me about 4 hours to do the job but I did some clean up of the suspension and fender wells while I had my Taco on stands.
    I prefer to use certified Toyota parts rather than after market. The wheel bearing never failed totally but it was indeed bad on one side and would have failed eventually. I just giddy when I save that much money and keep my Taco in tip top shape. Was not a difficult job.
  2. May 4, 2016 at 3:35 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I'll DIY when the passenger side goes but when the drivers side went it cost me $800 at a tire shop for the one side so the price they quoted wasn't too bad - I live in Jersey so maybe that was the difference - where R U ?
