Front Wheel Suddenly Stops Spinning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ranger098, Jan 16, 2017.
  1. Jan 16, 2017 at 1:33 PM
    ranger098
    ranger098 [OP] Well-Known Member
    Brian
    Minnesota
    I had to replace my wheel bearing, front passenger side. After taking the wheel off I was trying to spin the hub and noticed that it stopped pretty hard at a specific point. I could force it to turn over again, then it would spin normally until it made a full rotation then it would bind up again. I finished swapping the wheel bearing and it's still like this. Even with the wheel on, I can spin the wheel and it will rotate freely until it hits something and binds. Then I have to force the wheel past whatever it's binding on to continue spinning. Anyone know what's up?
  2. Jan 16, 2017 at 1:34 PM
    odinsbro15
    odinsbro15 Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    sounds like the break hitting the rotor
    teamfast likes this.
  3. Jan 16, 2017 at 1:37 PM
    ranger098
    Brian
    Minnesota
    I had the rotor off, spinning the hub by itself...
  4. Jan 16, 2017 at 1:44 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    4x4?
    odinsbro15 likes this.
  5. Jan 16, 2017 at 2:08 PM
    odinsbro15
    Eric
    LOS ANGELES CA
    yea 4x4 or 4x2? sound like 4x4 hub locked
    12TRDTacoma likes this.
  6. Jan 16, 2017 at 2:18 PM
    ranger098
    Brian
    Minnesota
    Sorry shoulda specified yes it's a 4x4.
  7. Jan 16, 2017 at 2:26 PM
    10MGM
    2010 AC MGM 4x4
    Is suspension fully extended when this occurs? If so, jack under lca to reduce angle of cv.
  8. Jan 16, 2017 at 2:29 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Cv joint is binding
  9. Jan 16, 2017 at 2:46 PM
    ranger098
    Brian
    Minnesota
    Wow great call, Jacking the Lca made the binding almost completely Disappear. So should I be concerned about the very very slight binding I notice now? I have a 900 mile road trip in a couple weeks....
  10. Jan 16, 2017 at 2:48 PM
    anthony250f
    Anthony
    San Diego, CA
    I would probably change the cv axles...mine is doing it too.
  11. Jan 16, 2017 at 2:49 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Not unless you plan on having both LCA fully down the entire drive. :rolleyes:
  12. Jan 16, 2017 at 2:50 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    They're binding because they're at full droop. You'll be fine on your road trip.
    What do you have done suspension wise?
    odinsbro15 and o0oSHADOWo0o like this.
  13. Jan 16, 2017 at 2:56 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    This ^^^^
    If you have a lift, It may have changed the suspension and drive geometry enough to cause the CV joints to bind when the LCAs are fully down.
  14. Jan 16, 2017 at 3:04 PM
    10MGM
    2010 AC MGM 4x4
    Do as you wish. You know that there is a problem and it is not going to get any better by itself.
  15. Jan 16, 2017 at 3:17 PM
    ranger098
    Brian
    Minnesota
    I have a 2" leveling kit, the left side doesn't bind but the right side does. Might be a problem there...
