Front wheels are bowing in on bottom
Discussion in '1st Gen. Tacomas (1995-2004)' started by ivan ny, Nov 27, 2021.
  1. Nov 29, 2021 at 1:29 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Any alignment shop should be able to work on our trucks, but I'd read some reviews. Some shops offer packages where you can buy a year (or several) worth of alignments. If you think there's a chance that your LCA cams are seized it might be worth buying one. Would suck to pay for an alignment then have to fix your LCA bushings and pay for a second alignment after.
    Could ask the shop if they'd let you bring it back for a free/discounted second alignment if that ends up being the case.
    ivan ny[QUOTED][OP] likes this.
  2. Nov 29, 2021 at 3:11 PM
    ivan ny
    ivan ny [OP] Well-Known Member
    2003 2.7 manual ext.cab
    will definitely ask before getting anything done
    does anyone know if that turns out to be the case will drenching them with some pbblast driving a bit giving them a while before doing anything might breakem loose that’s what I did when I did my leaf springs most people I’ve seen online were saying they had to cut that one bolt because it seizes in the bushing I didn’t I just kept spraying it and drove it for while before I did the job and was able to get it out with a ratchet was wondering if it’s sort of the same type of situation
