Frontier bed extender on Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fagro, Jun 17, 2011.
  1. Jun 17, 2011 at 6:11 PM
    Fagro
    Fagro [OP] Active Member
    RI
    10 DC LB SR5
    Extang Trifecta, LED Console lighting, VentShades
    Was wondering if a bed extender from a 00-04 Frontier will fit on a 05+ Tacoma. I have the extended, it fits between the tailgate pillars, but don't have a bracket kit for it. Should I get a Frontier bracket kit or a Tacoma bracket kit?
  2. Feb 25, 2019 at 4:46 PM
    Glenn247
    Glenn247 Well-Known Member
    Lynchburg VA
    2016 DCSB Manual TRD Sport 4x4
    I have this same question?
  3. Feb 25, 2019 at 4:56 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Have pics of the bed extender?
  4. Feb 27, 2019 at 3:05 PM
    Glenn247
    Lynchburg VA
  5. Feb 27, 2019 at 4:09 PM
    Marcus Israd
    Marcus Israd Well-Known Member
    Concord, CA
    09 TRD Sport SR5 4x4
    2009 Tacoma 4.0L Double Cab 4x4 Pyrite Mica Front: Yukon 4.88's ARB Locker Bilstein 5100's/Eibach Springs Camburg Uni-Ball UCA's Solo Motorsports Steering Rack Marlin Crawler LCA & Frame Braces Wheel bearings/Hubs by "05taco4x4" Crown Extended SS Brake Lines Stoptech Cryo Slotted Rotors/TRD Pads Wheeler's Super Bump Stops Rear: Yukon 4.88's ARB Locker Bilstein 5125's/All-Pro Expo Leaf Springs Ruff Stuff U-bolt Flip Crown Extended SS Brake Lines Timbren Bump Stops Intake/Exhaust: TRD CAI w/ AFE Dry-Flow Filter & TRD Exhaust (cut at axle) Lighting: Ultimate Headlight Upgrade by "crashnburn80" Fog light anytime mod Baja Designs S8 20" Light Bar Baja Designs Squadron Pro Fogs Armor: Pelfrybilt Steel Front Bumper BAMF Steel Skid Plates BAMF Weld-on Rock Sliders BAMF Front Bumper Supports Wheel/Tires: Pro Comp 17"x9" Wheels (x5) BFG KM3's - 35/12.5/17 Recovery: Warn M8000s Winch w/ Synthetic line Misc.: SoftTopper Ultra-Gauge Hurst T-handle Shift Knob Energy Suspension Urethane Radiator Support Bushings Pro Eagle Jack Midland CB Pine Tree Air Freshener Fluids: Amsoil
  6. Feb 27, 2019 at 4:12 PM
    Glenn247
    Lynchburg VA
    Thanks for that link, but wouldn't this one install differently than the Tacoma OEM one?
  7. Feb 27, 2019 at 4:14 PM
    Glenn247
    Lynchburg VA
    If I have to install it that way, and not by getting brackets that attach to the bed rails which is what I would prefer, what bracket set do I need to order?
  8. Feb 27, 2019 at 4:22 PM
    Marcus Israd
    Concord, CA
    Hard to tell by the pictures in the Craigslist add as to what connectors it has but I'd probably go with the Frontier ones to be safe. The pieces that you attach to the truck just get drilled into the bedside so they technically don't need to be Toyota, just need to match the extender.
  9. Feb 27, 2019 at 4:23 PM
    Glenn247
    Lynchburg VA
    Are there any brackets that will allow me to attach it to the bed rails rather than installing new adapters?
