Frozen Bolt Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Invid, Jun 30, 2019.
  1. Jun 30, 2019 at 4:21 PM
    Invid
    Invid [OP] Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    So the rear 24mm differential fill plug is frozen on tight. PDBlaster and heat did not assist in removing that bolt. The corners are now rounded off some and I am at a loss for a resolution. Any ideas on how to remove this? I will buy a new fill plug/bolt and washers but I need to get this off. Thanks!
  2. Jun 30, 2019 at 4:24 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Get a 6 point 24 mm socket. You are working on a 2016? Shouldn’t be that much corrosion. Do you have a breaker bar? 18-24 inch?
  3. Jun 30, 2019 at 4:29 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    What did you apply the heat with?
    Since you’re getting a new plug, heat it again and get on it with a freshly jawed pipe wrench. The bigger the better.
  4. Jun 30, 2019 at 4:30 PM
    Bishop84
    Bishop84 Well-Known Member
    If its rounded, only a high quality wrench or socket will grab it now.
    With rounded fill plugs, I use an air chisel, but a normal one will do.
    I chisel in a dent on the plug, then walk the dent around to loose the bolt. Very easy.
  5. Jun 30, 2019 at 4:31 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    More heat you didn’t get it hot enough...heat the area just around the bolt. If your rounding the corners you don’t have proper leverage...get a longer bar keep the socket square on the bolt.
    FloridaSon likes this.
  6. Jun 30, 2019 at 5:06 PM
    Invid
    2016 Tacoma Limited
    I used a torch but ddi t want to over do it. I have a breaker bar and used a 12 point socket. I'll see if I can find a 6 point.
  7. Jun 30, 2019 at 5:07 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Heat unsticks everything. Get that bitch glowing. It will come out.
  8. Jun 30, 2019 at 5:08 PM
    Invid
    2016 Tacoma Limited
    Lol l try it.
    shakerhood likes this.
  9. Jun 30, 2019 at 5:08 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I worked on an S10 last year that had a frozen diff plug, I threw some heat on it and put a floor jack under my breaker bar and pumped it loose.
    black coffee, hiPSI and stun gun like this.
  10. Jun 30, 2019 at 5:12 PM
    TripleEight
    TripleEight Well-Known Member
    2016 Tacoma TRD Off Road DCSB Gray
    Monkey wrench
    e6400ultra likes this.
  11. Jun 30, 2019 at 5:17 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Just a small warning... if you get it red, that's fine. If you get it white, wait a minute or so or else you'll twist the head off.
  12. Jun 30, 2019 at 5:18 PM
    Invid
    2016 Tacoma Limited
    My Robo Grip did little to help. I'll try more heat.
    Stocklocker likes this.
  13. Jun 30, 2019 at 5:19 PM
    stun gun
    Aaronski
    Tacomas.
    How long is this robo grip?
  14. Jun 30, 2019 at 5:21 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    About 10 minutes.
    stun gun[QUOTED] likes this.
  15. Jun 30, 2019 at 5:22 PM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    I would aviod using anything like these . Robogrip that is.
  16. Jun 30, 2019 at 5:22 PM
    stun gun
    Aaronski
    Tacomas.
    Ok cool I’ll be quick
    hiPSI[QUOTED] likes this.
  17. Jun 30, 2019 at 5:24 PM
    stun gun
    Aaronski
    Tacomas.
    OP, show us some pics of the rounded off plug and what you’re working with. Because if you have a pencil torch and a little robo grip we may need to step back and re evaluate.
    Frankenstuff likes this.
  18. Jun 30, 2019 at 5:25 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Don't forget I am one of a few who speak stungunese...
  19. Jun 30, 2019 at 5:28 PM
    stun gun
    Aaronski
    Tacomas.
    That is so convenient. I hate having to scream and point whenever I’m hungry.
  20. Jun 30, 2019 at 5:29 PM
    Frankenstuff
    Frankie
    This guy.
