Frozen Bolt Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Invid, Jun 30, 2019.
  1. Jun 30, 2019 at 9:06 PM
    #41
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    I can't get a visual of the bolt size or location and so I don't know how much room you are working with.
    I once used a manual hand impact driver after I used a cutting wheel to cut a slot in a large bolt.
    You use the fattest driver bit, and a small sledge hammer to torque the bolt out.
  2. Jun 30, 2019 at 9:13 PM
    #42
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
  3. Jul 2, 2019 at 9:08 AM
    #43
    Invid
    Invid [OP] Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I didn't use a breaker bar though.
  4. Jul 2, 2019 at 9:25 AM
    #44
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    PB Blaster is good. Tri-Flow is better.
    stun gun likes this.
  5. Jul 2, 2019 at 9:30 AM
    #45
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Mouse milk even more better.
    Skydvrr likes this.
  6. Jul 2, 2019 at 11:08 AM
    #46
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Sqaw piss, ultimate more better.
    stun gun[QUOTED] likes this.
  7. Jul 2, 2019 at 11:13 AM
    #47
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    Pee On It... It will most likely take more than one application.
  8. Jul 5, 2019 at 8:19 AM
    #48
    Banker
    Banker Well-Known Member
    OHio
    2017 Sport TRD DCSB
    @Invid
    Can we get an update?
  9. Jul 5, 2019 at 8:44 AM
    #49
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    Add viper semen to some whiskey, then pour that on the bolt followed by a bit of Monster Energy. That will fix it.
  10. Jul 6, 2019 at 12:53 PM
    #50
    Invid
    2016 Tacoma Limited
    I got a six point socket today so I will try that. Push comes to shove I'll buy another fill plug and do what I need to with this one.
  11. Jul 6, 2019 at 1:09 PM
    #51
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    This is a good strategy!! PB Blaster worked really well on my Saab 9-5 caliper bolts. Just give it time to work.
    DrFunker likes this.
  12. Jul 6, 2019 at 1:29 PM
    #52
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I may have already missed this suggestion but if it hasn’t been thrown out there yet I’d say whatever you get on the head of that thing use some sharp blows with some type of sledgehammer. I’ve always had way better luck “shocking” things vs brute strength. Same principal as an impact gun.
  13. Jul 12, 2019 at 9:37 AM
    #53
    DrVenkman
    DrVenkman New Member
    Southern Minnesota
    2009 AC 2.7L manual
    I know someone has already mentioned this, but I had this exact problem last week. The fill bolt was completely rounded out. The only thing that worked for me was a bolt extractor socket. I bought this set off Amazon cause I couldn’t find one large enough at a local store.
    IRWIN Tools IMPACT Performance Series BOLT GRIP Deep Well Bolt Extractors, 1/2-inch Square Drive, 6-Piece Lug Nut Set with 1/4-inch Hex Drive to 3/8-inch Square Socket Adapter (1859146) https://www.amazon.com/dp/B00LFRRZVY/ref=cm_sw_r_cp_api_i_gylkDbN3N7Q8K
    After some pounding and cranking it finally let loose.
    Sorry I’m still figuring out this app. That link doesn’t look functional
  14. Jul 12, 2019 at 9:45 AM
    #54
    Invid
    2016 Tacoma Limited
    Thankfully mine came loose after copious amounts of Blaster PB and a new six point socket. The corners weren't too bad but I ended up buying a new fill plug anyway.
    over60 likes this.
  15. Jul 12, 2019 at 9:47 AM
    #55
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Tack weld a nut to the plug and unscrew it off.simple
  16. Jul 12, 2019 at 10:09 AM
    #56
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    OP, is your truck 4WD? If so you might want to check the fill plug on the front diff and make sure its not seized as well. They can be a real PITA if they're anything like the ones on the second gens which strip easy as hell. Better to loosing it up a little before it has a chance to seize up.
  17. Jul 12, 2019 at 10:58 AM
    #57
    Invid
    2016 Tacoma Limited
    Nah just a 2WD
  18. Jul 12, 2019 at 10:59 AM
    #58
    wawuzit
    wawuzit Well-Known Member
    steve
    Clinton, Tennessee
    2019 gray 4dr Tacoma TRD
    none
    http://i.ebayimg.com/t/EASY-OUT-6PC-SET-CASE-1-8-3-4-HI-GRADE-STEEL-/00/s/OTI3WDEyMDA=/$(KGrHqF,!qcF!b-sFes-BQPBrT2Ng!~~60_57.JPG
    easy out set. You didn't say how thick the plug was. Beware...if you drill a small hole ( which s needed) there will be metal fragments goin into the gear area. This is a great tool but go slow. Using a lot of heat works but it can harden the female thread area , use some kind of lubricant that won't hurt the gears.
    BTW. You may think this is crazy but have you tried to TIGHTEN it a very small amount. You can break the bond. Go slow. Don't get carried away with force. Try the reverse impact feature on your drlll motor , go back and forth , forward and backwards.
    https://www.gasenginemagazine.com/restoration/how-to-remove-rusty-pipe-plugs-head-plugs
    If you double wrench it or put a cheater on the pull handle of a ratchet you can cause a crack in the metal surrounding the plug. Be careful.
    Does it look like the photo below? There are all kinds of designs used in plugs.
    https://www.carid.com/ic/acdelco/products/images/8672354_6.jpg
    #58
  19. Jul 12, 2019 at 11:05 AM
    #59
    Pyrotech
    Pyrotech Well-Known Member
    Mix of ATF and acetone.. works pretty good as wl
    baldbeardedtaco likes this.
  20. Jul 12, 2019 at 11:21 AM
    #60
    wawuzit
    steve
    Clinton, Tennessee
    none
    Please wear glasses if you decide to use Acetone.
