Frozen Bolt Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Invid, Jun 30, 2019.
  1. Jul 12, 2019 at 11:39 AM
    #61
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    I find it hard to believe a long ass breaker bar wouldn't budge it after a soak of pb blaster
  2. Jul 12, 2019 at 12:05 PM
    #62
    Invid
    Invid [OP] Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I said earlier that I didn't use a breaker bar though.
  3. Jul 12, 2019 at 3:03 PM
    #63
    ELT2JV
    ELT2JV Well-Known Member
    17 TRD OR ACLB
    8112 front 8100 rear. Method NV with 265/75/16 KO2.
    Not in my industry. Some times its just sheer force. But we only deal with 1,000,000ft/lbs
  4. Jul 12, 2019 at 3:12 PM
    #64
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    This… but I would say works better than just pretty good. It has been my go to for rusted/seized nuts and bolts when nothing else seemed to work so now if needed I spray the night before to soak and prior to.
    Last truck was so rusted that I have also added a map? Torch (it’s the yellow can) and a harbor freight 29 gal compressor with a heavy duty impact wrench and hammer.
  5. Jul 12, 2019 at 3:21 PM
    #65
    wawuzit
    wawuzit Well-Known Member
    steve
    Clinton, Tennessee
    2019 gray 4dr Tacoma TRD
    none
    Has that plug ever been removed since new? You don't have to tighten that plug like it was a lug nut on the wheel. Some plugs even have an O ring.
  6. Jul 12, 2019 at 3:48 PM
    #66
    baldbeardedtaco
    FL
    You quoted the wrong person
  7. Jul 13, 2019 at 3:50 PM
    #67
    Invid
    2016 Tacoma Limited
    Yes by the dealer when they replaced my differential gasket for the TSB. I assume they used an impact wrench.
  8. Jul 13, 2019 at 3:58 PM
    #68
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    borrow a 23mm socket,pound it on with a hammer flush, breaker bar, pray
  9. Aug 1, 2019 at 1:25 PM
    #69
    Invid
    2016 Tacoma Limited
