Frozen drain plug on the oil pan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GraceB, Oct 25, 2012.
  1. Oct 25, 2012 at 7:55 AM
    GraceB
    GraceB [OP] New Member
    Wisconsin
    2006 Tacoma
    At the end of my oil change at the dealer today, the service advisor tells me the oil plug was frozen to the pan and the threads stripped when they took the plug out. My Tacoma is a 2006 with 136k on it. The advisor tells me it will be $379 to replace the lower part of the oil pan and new plug--is this a normal issue to be expected after changing the oil every 5k??:(
  2. Oct 25, 2012 at 8:02 AM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    The oil plug would never freeze to the pan if the proper drain plug washer was being used all the time. Sounds like someone wasn't using the washer and over tightened it last oil change
  3. Oct 25, 2012 at 8:04 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    well that sucks!
    i have never had an oil plugs seize. it is bathed in oil from the other side. that tiny pan cannot be that difficult to change out.
  4. Oct 25, 2012 at 8:04 AM
    blazze2005
    South Jersey
    Tell them you wanna see the drain plug and washer. If no washer is present then it's their fault for not using one last oil change.
  5. Oct 25, 2012 at 8:04 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    No, it's not normal. It means either the mechanic taking the drain plug out went in first, stripping the plug, then backed it out or the last person to do your oil change put the plug on way too tight and stripped the plug.
    You don't need a new casing either, you can tap in new threads and salvage the old one, might need to get a different sized bolt though depending on how bad it was.
  6. Oct 25, 2012 at 8:28 AM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    I agree, take a look at the bolt for cross threading and or crush washer missing.
  7. Oct 25, 2012 at 8:40 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    ^X2
    oversized drain plugs are a common find
    Justin
  8. Oct 25, 2012 at 12:37 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    If you had the last oil change done at the dealer and you have a receipt then that means the dealer stripped it and owes you another. Besides, $379 for that tiny little pan? That's insane! Those crooks :mad:
  9. Oct 25, 2012 at 12:38 PM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    use this opportunity to install a fumoto drain valve...
  10. Oct 25, 2012 at 12:48 PM
    98tacoma27
    Ben
    Not Beech Creek
    X2
    If you have no other option but to purchase the pan...Post here and ask Jorge for a quote.
    The pan is less than $50 for the 4.0 and $100 for the 2.7.
  11. Oct 25, 2012 at 7:13 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Depending on how severely they wrecked shit...
    1. Pull the pan and tap the hole and chase the threads on the plug or get a new plug
    2. Pull the pan and weld a new bung onto the pan, either over the stock hole, or in a new hole next to it. Find a way to plug the old hole if not welded over it.
    those are my suggestions
  12. Oct 25, 2012 at 7:20 PM
    WickedTaco
    WickedTaco Well-Known Member
    Aaron
    Treasure Coast, FL
    '11 Silver DC TRD OR 4x4
    iPod Interface, Bully Tailgate Lock, ScanGaugeII
    ^This. Installed mine a year ago and I highly recommend it as well. Makes oil changes even easier than they were ready. And not even the hint of a spilled drop of oil.
  13. Oct 25, 2012 at 7:27 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Steel plug, steel pan. Only reason this would happen is technician error. I always use one shop for everything. That way, no games. The last shop wanted to play games after stripping my plug out. They lost my business for good. I knew they did it, because they had done the last dozen oil changes. Fortunately, I was about to trade the truck in, so I let them pay for the oversize drain plug and install it for me. I'm sure it's still running around with that plug in, but I'd prefer factory parts as a repair on a vehicle I plan to keep. Luckily Toyota made it easy to change the lower pan out.
    It looks like a one hour job to change that pan if the oil is already being changed. The price they are quoting is a ripoff.
  14. Oct 25, 2012 at 7:35 PM
    budget76
    budget76 Active Member
    New Jersey
    98 xt-cab 4x4 4cl/2.7 stock man
    soon want dual lockers Picture was my 85 dual arb great
    I remember my dad fixing this problem with a $4.95 rubber drain
    plug which is reusable. replace every 20k miles.
    works
    not proud but works
  15. Oct 25, 2012 at 7:38 PM
    aficianado
    back to bone stock.
    I'm guessing OP doesn't DIY.
  16. Oct 25, 2012 at 8:58 PM
    Larry
    Larry CARL
    CARL
    who did last oil change?
    without this info...and seeing the pan bolt and washer (as mentioned)...I withold opinion.
