Frozen out of my truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by YellowDog01, Dec 27, 2010.
  1. Dec 27, 2010 at 8:30 AM
    YellowDog01
    YellowDog01 [OP] Well-Known Member
    04 4x4
    South Carolina doesn't get snow much, so I'm all new to this.
    We left to go out of town over Christmas, so my truck sat for 5 days. This morning I go to get in it and the key won't go in. I don't have any keyless entry so I heated up the key and it took about 5 minutes to get the door open...Now only 2 of the doors are frozen shut.
    Anyone know a better way to fix it?
  2. Dec 27, 2010 at 8:32 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    you can get some "de-icer" aerosol spray that works pretty good. i have used it to thaw frozen locks
  3. Dec 27, 2010 at 8:37 AM
    YellowDog01
    04 4x4
    Thanks! I'll look for it
  4. Dec 27, 2010 at 8:37 AM
    CaptMorgan
    CaptMorgan Well-Known Member
    Tempe
    Lift, tires, aux-in, LED Taillights, Flowmaster
    this is partially why I love AZ, this is from my Android phone just moments ago
  5. Dec 27, 2010 at 8:42 AM
    pudge151
    Sean
    Connecticut
    i think its acetone or ethenol, rubbing alcohol should also work
  6. Dec 27, 2010 at 8:46 AM
    MTgirl
    Weesa
    Bob's secret mod lair
  7. Dec 27, 2010 at 8:46 AM
    PhatTaco
    PhatTaco Well-Known Member
    Jerry
    Georgia
    07 PreRunner SR5
    Backup camera, wheel locks, locking gas cap, tailgate anti-theft device (hose clamp).
    NOT ACETONE DON'T USE ACETONE! Acetone is the active ingredient in nail polish remover and is used in paint thinner, I think it will damage the finish on your truck.
  8. Dec 27, 2010 at 8:52 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    In CT we get some bad ice storms and long cold snaps, not as bad as some parts of the country but still cold and wet. I have never had a lock freeze on me! Is there a reason for water to be getting into your locks? Seems like you should be looking to prevent it freezing not just find the best way to thaw it, but like I said it never happened to me so I don't really know.
  9. Dec 27, 2010 at 8:54 AM
    TacoDaTugBoat
    Goshen, Ct
    13 DCLB TRD Sport
  10. Dec 27, 2010 at 8:59 AM
    MTgirl
    Weesa
    DUH!!! :p
    I found some neat, single use ones (smaller than a chap stick tube) that I keep around...usually one in my purse (maybe not an option for you guys ;)) and one in my desk and back when I was going to school I had one in my backpack.
  11. Dec 27, 2010 at 9:15 AM
    YellowDog01
    04 4x4
    Well I think I might grab a keyless entry before I go out there.... And 4x4.. Haha
    I'll look into it, thanks.
  12. Dec 27, 2010 at 9:15 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Common problem with all vechicles, Back Colorado, we just did not lock the doors, lived in a very rural area, I know might be viable in an urban setting.
  13. Dec 27, 2010 at 10:12 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    hair dryer. .....seriously.
  14. Dec 27, 2010 at 11:01 AM
    YellowDog01
    04 4x4
    It rained the night before and then snowed so it just had water on the truck.
  15. Dec 27, 2010 at 11:06 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    try gettin some liquid graphite and puttin it in the lock hole too. i done that to mine and its never frozen.itll also lubricate the lock and help it work alot better. had to use it on my undercover tonneua a few times and the locks work better than new. doors are a different story. weve been gettin winter weather here and so far my doors werent stuck shut. i usually clean off as much of the snow as possible so everything can dry out before nightfall. that seems to help me just fine.
  16. Dec 28, 2010 at 4:49 PM
    YellowDog01
    04 4x4
    That might be my new signature quote! hahahaha
  17. Jan 1, 2011 at 3:41 AM
    Canadian Girl
    Canadian Girl Well-Known Member
    Kim
    Ontario, Canada
    07 X Runner
    Billet 5 piece Grille, Pink X-Brace, Pink Devil Horns, Stereo with Sub-X, short shifter, URD intake, Xii street drop, Vinyl custom interior dash,......... for now ;)
    If your ever stuck pee on your lock. I know it is not the best thing to think about or even want to do but Men....pee on your lock...warm liquid..... and your key....it will work..... :)
  18. Jan 1, 2011 at 6:16 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    the WD in WD-40 means "water displacement". a light shot of that in the lock works wonders for keeping the mechanisims unfroze. one little spritz from the can with the red straw inserted will do the trick.
    Don't forget to lube the door seals, so when you do get a cold morning and try to peel the door open,,you dont peel chunks of door seal off with it,,thus having a water leak later in the year.
    http://www.amazon.com/AGS-Door-Ease-Lube-Stick/dp/B000FW7UBA
    stuff I use for lubeing the door seals. apply liberally.
  19. Jan 1, 2011 at 6:59 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Mod is spot on ---- WATER DISPLACEMENT! WD40 will do the trick.
    Personally I use White Lithium Grease, a little on the key and work the mechanism a few times. Part of my winter prep routine. Also grease the latches and hinges. You only need a light coat to displace whatever moisture gets in there. It's not always leaking in, cold and then warming will create condensation on metal, or maybe the frost just melts, result is the same.
    Been using can of silicon spray on my rubber seals, but I need to check on the "Door Ease Lube Stick." Have to be careful with the silicon spray or it gets a little messy. Thanks Mod.
    I'm in Alaska, 7 to 8 months of winter is the reason.
  20. Jan 1, 2011 at 7:44 AM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    Come to Lousy-ana. Bone chilling 74 degrees right now.
