Frozen rear diff breather
Discussion in 'Technical Chat' started by DavesTaco68, Jan 5, 2022.
  1. Jan 5, 2022 at 6:35 PM
    DavesTaco68
    DavesTaco68 [OP] Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I did the rear diff breather mod a few years ago, located the breather to the drivers side cubby - no issues. It’s been really cold here lately and my breather line must have gotten plugged with frost and ice. I toasted my rear driver side axle seal and the bearing on that side as well. Just a heads up if you live where it gets really really cold you might want to occasionally check your your diff breather. I did a 7 hour Hwy drive with temperatures around -35 Celsius plus wind. Stopping for gas I noticed diff fluid on my wheel.
    3JOH22A likes this.
  2. Jan 5, 2022 at 6:43 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    a trip that long Condensation being pushed out the differential it froze in the long hose.
    Differential temperature got hot enough it pushed out the water vapor
    One of those Long drives do strange things
    Normal drives around home it most likely would never have happened.
  3. Jan 5, 2022 at 7:27 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    Yeah your probably right on that, its a case of a 10 dollar part costing me a few bucks!
    Bivouac[QUOTED] likes this.
  4. Jan 9, 2022 at 12:38 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    not sure what size hose U might have used
    if U think this might be a recurring issue
    get a piece of old metal guitar ( bass 1/2 to 34 diameter) string
    correct length run it back / forth a few times
    keeps tubing clear
  5. Jan 9, 2022 at 12:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    So you're suggesting a G string for his rear to be able to breathe correctly?
    Bivouac, tinker_troy and RedWings44 like this.
  6. Jan 9, 2022 at 12:46 PM
    ROAD DOG
    FEW
    YES !!
  7. Jan 9, 2022 at 12:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ve had it happen to me.
    I’m not an engineer, but there has got to be a better setup. I’ve seen this happen on more than one Tacoma.
    Next time I replace mine. I am thinking about going with an open vent. Still haven’t thoroughly thought it out.
  8. Jan 9, 2022 at 1:40 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    I'm probably going to use the stock breather for winters, if everything is frozen the heat from the diff should keep the little vent going vs the longer hose up to the bed with the breather which could freeze up due to no heat and frost build up. Its' a painful bill to replace the seals. This winter things were colder than normal, the two previous winters I had no issues.
  9. Jan 9, 2022 at 6:02 PM
    ROAD DOG
    FEW
    truly does NOT rise to the level o desperation
    if no high water creek crossings unlikely there is a need to extend the vent
  10. Jan 9, 2022 at 6:10 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Interesting. Never had that happen to me in those temperatures or lower.
  11. Jan 9, 2022 at 6:21 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Can't imagine there would be so much condensation to ice up and completely plug up a 5/16" hose, maybe at the breather where the gaps are smaller. Try a larger vent (like a Uni Filter) instead of the stock-shape breather with the small metal cap.
  12. Jan 9, 2022 at 6:40 PM
    TnShooter
    Deogee
    STOCK
    Pretty sure mine was the vent. If you can’t jiggle it, it’s stuck. (Best I can do to describe it)
    I have had to twist/turn mine to free it up.
    I have no conclusive evidence it is the vent causing the issue.
    But the 1st time it leaked out the the seal, the vent was stuck.
    I replaced vent and seal.
    The 2nd time it leaked, the vent was stuck.
    I did NOT replace the seal, I freed up the vent and it hasn’t leaked since.
    (And yes, I know about the rear bearing being affected by the leak.
    But that isn’t what I’m talking about here.)
    Also, my vent is in the same place it was when it left the factory.
    I have not extended it or modified it in any way.
    DavesTaco68[OP] likes this.
