Frozen rear wheel on 2019 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bradcash, Dec 26, 2022.
  1. Dec 26, 2022 at 9:16 AM
    bradcash
    bradcash [OP] New Member
    2019 tacoma
    What are the probable reasons for frozen rear wheel? Would powertrain warranty cover this? If no warranty what are probable costs?
  2. Dec 26, 2022 at 9:16 AM
    OuchIDied
    OuchIDied Well-Known Member
    2021 Silver Sky Tacoma Off-Road
    Probably gonna need more details. Parking brake on and frozen? That's pretty common.
    Chew, Rock Lobster and whatstcp like this.
  3. Dec 26, 2022 at 9:18 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. Seems that this happens when water gets into the rear brake drum. Most people just rock it back and forth to free it up.
  4. Dec 26, 2022 at 9:18 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Probable reasons for frozen rear wheel: The cold.
    You should explain a bit more about what you mean. If you're referring to the parking brake sticking, this is a common occurrence when the weather gets below freezing.
    Chew likes this.
  5. Dec 26, 2022 at 9:19 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Thirded - parking brake.
  6. Dec 26, 2022 at 9:25 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Another reason to move to south Florida :bananadance:
  7. Dec 26, 2022 at 9:25 AM
    bradcash
    2019 tacoma
    Rear right wheel is the only wheel frozen. It's been rocked repeatedly. It was cold when it froze but it's been 40 then 50 degrees for 2 days.
  8. Dec 26, 2022 at 9:31 AM
    Trail Limo
    Trail Limo Well-Known Member
    Mine does this when I go through the carwash and then use the parking brake without letting it dry first. Fix is put in 4 low to break it free.
  9. Dec 26, 2022 at 9:34 AM
    eurowner
    eurowner Duke Sky
    Scoty
    This happened to me too, it was 50* out so the water was not frozen.
  10. Dec 26, 2022 at 9:36 AM
    Trail Limo
    Yup. It's the rust that makes it stick, not ice.
  11. Dec 26, 2022 at 10:03 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I would bang on the wheel and tire with a rubber mallet a few times. That would dislodge it sticking from rust/ice/gum/etc.
  12. Dec 26, 2022 at 10:22 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Hammer on the brake drum. Try turning the star adjuster to retract the shoes.
    Be careful trying to break it free by brute force. In some cases the backing plate will get deformed. Replacing the backing plate requires separating the driveshaft/wheel flange from the bearing. That's a big job requiring a hydraulic press and bazooka-sized press tool.
