frozen reservoir
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hayseed, Jan 2, 2018.
  1. Jan 2, 2018 at 10:28 PM
    Hayseed
    Hayseed [OP] Well-Known Member
    Dave
    WV
    2016 Tacoma sport TRD
    Clazzio vinyl seat covers, decal, auto drop running boards, chrome rear letters chrome rear tail light bezels and bed release cover. Painted grill, polished aluminum cover over black grill in sport hood. Polished alum. wheels. Form fitting flor mats
    What are the steps to removing windshield reservoir? I put fluid in and last night it froze solid. I tried a heat gun but think I may have to remove and bring inside. But the damn thing is hard to get out for some reason
  2. Jan 2, 2018 at 10:34 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Trying to drain it? I just leave mine dry in very cold weather but it sucks when it's frozen or empty and you are following cars in muddy slush.
    wilcam47 likes this.
  3. Jan 2, 2018 at 10:35 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    If I remember correctly it’s just one or two bolts holding it down. Pretty easy to see if you are looking at it from the top. Can’t remember if it was a 7/16. Then pull straight up, since there is some kind of bushing that’s it’s kinda pressed in in the bottom.
  4. Jan 2, 2018 at 10:36 PM
    SweatyBiscuit
    SweatyBiscuit Well-Known Member
    Paul
    Northern AZ
    2016 Taco TRD OR
    Katzkin leather, heated seats, Popnloc, bed lights, remote start, bhlm....
    I don’t recall exactly but I remember it being fairly straight forward. I had it out when I upgraded to hid headlights (the exact method may be in one of those write ups). Seems like there was a bolt or two (10mm I think) and then you could rock it back towards the back of the engine bay and unclip the sensor. After that pull it straight out in an upwards move and pull the hose.
    shakerhood and 9TRDTCO like this.
  5. Jan 2, 2018 at 10:37 PM
    9TRDTCO
    Beat you to it! Almost similar post too lol
  6. Jan 2, 2018 at 10:52 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Head to the pharmacy and get a bottle of rubbing alcohol. Pour that in and wait. It will melt the frozen fluid eventually.
  7. Jan 2, 2018 at 11:11 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    This Marine knows what it's like...Frozen reservoir
    Durango95, Sig45 and frusteri4 like this.
  8. Jan 3, 2018 at 12:10 AM
    OnHartung'sRoad
    Chosin Reservoir? Wow. I spoke with an old marine who said they used prechewed tootsie rolls from their rations to repair broken gas lines and fuel tanks in the winter there - it freezes into a gas resistant solid mass. There's a great short on the internet about their story doing it, too. https://m.youtube.com/watch?v=gDIv-byz7cQ A good trick to remember if you are broken down in a cold place. Bar soap makes a good gas tank hole plug, too. Anyways, that marine has my respect!
  9. Jan 3, 2018 at 4:39 AM
    peavey02
    peavey02 Well-Known Member
    Alex
    NC.
    2017 Tacoma TRD Pro
    RCI rock sliders OVT Tune KO2 265/75/16
    Two bolts on top and then pull straight up. It takes a lot. There is a plug on the bottom.
    Maybe 3 bolts. Would have to go check. Its really easy though.
  10. Jan 3, 2018 at 5:00 AM
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    Half hour of driving should thaw it out....
    Mines been doing it - but it's been below zero at night - and by the time I get to work, the spray works... Just start adding in some cold weather rated washer fluid
    floodedkiwi and wilcam47 like this.
  11. Jan 3, 2018 at 7:27 AM
    Hayseed
    Dave
    WV
    Thanks for all your help. I did take bolts out. This let me lean the tank back to get at the electrical connections. But I could not disconnect the pump. I saw some videos where they went in through fender well. Oh well! Thanks I will pour in the alcohol md hope it helps. I am only afraid of the freezing fluid cracking the reservoir? Again thanks
  12. Jan 3, 2018 at 7:29 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    i would mix the alcohol with some warm distilled water---should get that tank flowing in no time.
  13. Jan 3, 2018 at 8:47 AM
    Reedld
    Reedld Well-Known Member
    Leon
    Painted Post NY
    2022 DCSB Tacoma Army Green TRD Sport
    Just happen to me. Truck was used, bought in NC, I live in upstate NY. I suspect it was topped off with cheap fluid there. Removed tank on New Year's Day. 2 -10mm bolts, I couldn't remove electrical connection so I removed the pump/motor port into tank. Only bottom of tank was slushy. Emptied fluid, melted frozen soln in sink, reinstalled, filled with -20F rainX, then made sure it would spray ( so lines had good stuff).
    Instead of rubbing alcohol, use methanol or prestone windshield wash additive.
    Methanol is better than rubbing alcohol, google it.
  14. Jan 3, 2018 at 8:51 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Mine as well, by the time I got to work, it was thawed, rubbing alcohol and a more expensive fluid with lower temperature rating usually help...
  15. Jan 3, 2018 at 9:21 PM
    Exracer2
    Colchester Ontario
    Water defeats the purpose of adding alcohol (even hot water). You now have to purge your tank of the water or else it will freeze as well. Hot water will do nothing for the fluid in the lines whereas a high alcohol content will eventually melt the ice in the lines.
    Methanol or methyl hydrate works too but most people are more likely to have isopropyl alcohol (rubbing alcohol) in the house. If you don’t know the uses for methyl hydrate you probably don’t know where to buy it either even if every hardware store in town has it.
  16. Jan 4, 2018 at 5:04 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I'm telling ya! It is not only good for the gas tank but has other uses also.
    Reedld likes this.
  17. Jan 4, 2018 at 5:16 AM
    gearcruncher
    Canadain bumper technician
  18. Jan 4, 2018 at 5:17 AM
    Turbo-Taco
    Turbo-Taco Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    Mine use to freeze often after the dealer put in their 50-50 mix so now I use the Rain-X 2 in one all season washer fluid and that hasn't froze on me yet....its suppose to be good up to -20
    TacoCat likes this.
  19. Jan 4, 2018 at 5:19 AM
    gearcruncher
    Mine is frozen all the time , mind you it,s minus 40 where I live .
    Warm here this morning
    Thu Morning
    Mainly sunny
    -34°C
    Feels like: -36
    POP: 10%
    Wind: 3 km/h N
    Wind gust: 9 km/h
    Humidity: 70%
    Hourly Forecast
    hourly-weather-forecast
    Thu Afternoon
    Mainly sunny
    -26°C
    Feels like: -33
    POP: 10%
    Wind: 8 km/h N
    Wind gust: 15 km/h
    Humidity: 76%
    Hourly Forecast
    Thu Evening
    Clear
    -31°C
    Feels like: -40
    POP: 10%
    Wind: 8 km/h NE
    Wind gust: 15 km/h
    Humidity: 91%
    Hourly Forecast
    Thu Overnight
    Clear
    -35°C
    Feels like: -41
    POP: 10%
    Wind: 5 km/h NE
    Wind gust: 9 km/h
    Humidity: 91%
    Hourly Forecast
    over60 and TacoCat like this.
  20. Jan 4, 2018 at 5:23 AM
    Fiesta346
    Fiesta346 Well-Known Member
    PA
    2013 Tundra rock warrior
    Just had the same issue noticed it driving home on about a 40m drive. Once home I tried again and wouldn't you know it, wiper fluid was coming out. Some good old motor heat could be your solution...
