Frozen Taco!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HomerTaco, Nov 21, 2014.
  1. Nov 21, 2014 at 9:28 PM
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Heater took a shit today. :(
    Took the truck for a short local errand and the heat stopped working 10 minutes into the drive. Blower works at all speeds just zero heat.
    Thoughts?
  2. Nov 21, 2014 at 9:34 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    I'd check fuses, cabin air filter, I would also take it in if you can't figure out what's wrong with it. But I dont know what could be wrong with it.
  3. Nov 21, 2014 at 9:40 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Check passenger side floor board for water, antifreeze or any wetness. If any of those hello new heater core. And don't just look. Feel.
  4. Nov 21, 2014 at 9:44 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    As far as fuses we don't have electric heat in these trucks we get our heat from the water/antifreeze in our radiator being heated by the engine. Could have a bad thermostat but the truck would most likely overheat at that point. If it's not over heating and temp isn't rising my money is on the heater core bursting. Most likely cold temperatures, off roading and a combination of just shitty timing and pop. But luckily it's not the end of the world
  5. Nov 21, 2014 at 9:46 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Buy a jeep!
    The heater won't work in the first place, so nothing to break bwahahaha!
  6. Nov 21, 2014 at 10:35 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    If it was working and stopped while driving and the temperature gage did not suddenly drop I would guess a bad flow control valve or low on coolant and it sucked air into the system.
  7. Nov 21, 2014 at 10:39 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Craig, start with the most simple solution. Check your thermostat. If it is stuck open you will get no hot fluid to your heater core, thus no heat.
    I would remove it and place it in 190 degree water and see if it pops, if not, BOOM problem solved.
  8. Nov 22, 2014 at 4:44 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Clogged heatercore ? Try back flushing.
  9. Nov 22, 2014 at 5:18 AM
    pittsnogled
    pittsnogled I like turtles
    kirk
    South Carolina
    2014TRDsport
    5100's all around with OME 884 at 0. Weathertechs, Carhartt seat covers. BFG KO2's 265/70/17. T4R SEMA wheels. 18% tint on front windows. General Springs HD 4 leaf pack, Leer 100 XR shell.
    jeep heaters will bake your ass. never had a heater blow so hot so fast. fastest power windows i ever seen as well.
  10. Nov 22, 2014 at 5:18 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    X2... I don't remember how the hoses are routed, but see if the heater hoses are both warm. I'd guess having heat and then losing it right away would be more of a heater door control issue vs a coolant/blockage issue.
  11. Nov 22, 2014 at 6:08 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Thanks for the responses. I'll try to get a better look this weekend.
  12. Nov 22, 2014 at 6:25 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Probably just low on coolant. A vehicle can be down a 1/2 gallon or more and not actually overheat or show anything odd on the gauge. But it won't have enough volume for good heat. But then that begs the question: where did it go? Hopefully your check engine light doesn't come on with a misfire on cylinder six!
  13. Nov 22, 2014 at 6:56 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Our jeep's heater worked great. About the only thing that did.
  14. Nov 22, 2014 at 7:03 AM
    MTgirl
    Weesa
    Bob's secret mod lair
  15. Nov 22, 2014 at 7:07 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Very helpful my dear. :rolleyes:
  16. Nov 22, 2014 at 7:11 AM
    MTgirl
    Weesa
    I try :D
  17. Nov 22, 2014 at 8:07 AM
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    yep i agree do you have zero heat or just warm
  18. Nov 22, 2014 at 8:55 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    :laugh: You could make s'mores anytime you want. :cool:
  19. Nov 22, 2014 at 9:07 AM
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
    HOMER...I work for a local dealer if you get stuck..let me know if u need anything.
  20. Nov 22, 2014 at 9:32 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Your heater relay may have nuked.
