Frustrated - Bilstein 5100 Lift
Discussion in '4 Cylinder' started by SD Scott, Apr 9, 2016.
  1. Apr 9, 2016 at 1:00 PM
    SD Scott
    SD Scott [OP] Member
    Hi.
    I have a '13 DC PreRunner 2.7. I bought is new and still very much like it. Now that it has 85K miles I thought about lifting it a little and putting on some ATs. I bought the Bilstein 5100s for the front & back. Installed the fronts at the 1.85" lift setting. It lifted it 3-4" and the ride is horrible (most likely binding). This morning I took it apart again and dropped it down 1 notch to the 0.85" setting. Took it for a test drive, came back, and it measured exactly the same at 3-4" of lift. A quick measurement of the shock bolt to the spring base and there is almost a 2" difference from the stock shock to the Bilstein. I need to take the wheel off to get a better measurement. Even if I drop it down to the lowest notch on the Bilstein I think it will still be way more than the 1.85" I was planning on. Is there any difference in the UCA, LCA, or shocks from a 4 cylinder PreRunner to a V6 or even a TRD? Trying to figure out why there is so much lift.
    Thanks.
  2. Apr 9, 2016 at 1:04 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to TW. Did you get new springs or reuse your factory ones? If you did get new springs, which ones?
  3. Apr 9, 2016 at 1:14 PM
    JWL
    JWL Well-Known Member
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    OME 885, Bilstein 5100, JBA UCAs, 2" Single AAL
    Is your spring perch upside down?
    Welcome to TW!!
  4. Apr 9, 2016 at 1:16 PM
    SD Scott
    Thanks for the quick response. I reused the factory springs. I tried to call Wheeler's, which is where I bought them, to see if I received the incorrect shocks for some reason, but they are closed on Saturday.
  5. Apr 9, 2016 at 1:17 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    photos of your installed parts, if you would.
  6. Apr 9, 2016 at 1:20 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Your setup is upside down most likely.
    heel_touge likes this.
  7. Apr 9, 2016 at 1:21 PM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Spring perch is upside down.
    heel_touge and Hairy Taco like this.
  8. Apr 9, 2016 at 1:21 PM
    SD Scott
    Now that may be it! The spring perch! I'm going to check. Thank YOU!
  9. Apr 9, 2016 at 1:24 PM
    SD Scott
    At least now that I have done it twice I can get the job done a lot faster.
    digitaLbraVo likes this.
  10. Apr 9, 2016 at 9:24 PM
    SD Scott
    Update - Corrected the spring perches and everything is normal. I feel like a dumb a$$.
    Thanks to everyone.
  11. Apr 9, 2016 at 9:47 PM
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    It's happened enough times that one should not feel dumb for accidentally doing it. I'm sure if you knew they were upside down you wouldn't have done it. Glad you got it fixed!! Enjoy your new (and now much safer) lift!!!
  12. Apr 9, 2016 at 9:50 PM
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    The only stupid question is the one you don't ask,things like that are what started forums like this on every subject I can think of,that and batching about stuff hahaha
  13. Apr 9, 2016 at 9:57 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You ARE a dumbass & are in good company , most of us have derped at least one thing.. ( I myself have derped a few things)
    Glad you got it figured tho'...
    Hairy Taco likes this.
  14. Apr 9, 2016 at 10:01 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    It is apparently quite common, even when the work is done in a shop, so don't feel too bad.
  15. Apr 10, 2016 at 6:37 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    Questions answered.....And we'll never see him again :) lol
  16. Apr 10, 2016 at 9:51 AM
    SD Scott
    Actually, I couldn't find my old username & password, so I just created another.... Now that the front is done, I need some advice for the back.
  17. Apr 10, 2016 at 10:18 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You might want to get with a MOD here about the duplicate account tho'...
