Frustrated still f#@!kin misfires 2.4l
Discussion in '1st Gen. Tacomas (1995-2004)' started by boodacrf450, Sep 23, 2024.
  1. Sep 23, 2024 at 5:57 PM
    boodacrf450
    boodacrf450 [OP] Well-Known Member
    99 Tacoma 2.4L
    frustrated still misfires 99 tacoma 2.4l 445000 miles replaced plug wires coils injectors checked vacuum lines did compression test. don't know what to do next gonna order new vacuum lines although the old ones look fine any suggestions?????
  2. Sep 25, 2024 at 6:54 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Jeez, where to begin. What codes do you have?
  3. Sep 25, 2024 at 7:12 PM
    boodacrf450
    99 Tacoma 2.4L
  4. Sep 25, 2024 at 7:29 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    That's all?
    Spark plug gap? Leaky injector?
  5. Sep 25, 2024 at 7:32 PM
    Bishop84
    Bishop84 Well-Known Member
    All thats left is ECU/Wiring (unlikely) or mechanical/valves/cams/pistons (more likely)
    Need to check the valves for carbon/burn marks, a borescope with a side camera would be ideal.
    Cheap one here, not sure how clear it would be
    https://www.amazon.com/Dual-Lens-En...id=1727317953&sprefix=borescop,aps,177&sr=8-4
    You can also remove the intake manifold and peak at them while rotating the engine.
  6. Sep 25, 2024 at 7:55 PM
    boodacrf450
    99 Tacoma 2.4L
    Will do thanks gotta wait hurricane coming
  7. Sep 25, 2024 at 7:59 PM
    Glamisman
    Glamisman Well-Known Member
    What is the engine vacuum at idle?
    What is the MAF reporting as airflow in g/sec?
    What is the STFT @ idle, then 1000 rpm, then 2000 rpm?
    What does the freeze frame data show?
