Frustrated that my truck isnt...well..a truck!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by msapers, Aug 16, 2020.
  1. Aug 16, 2020 at 7:03 AM
    msapers
    msapers [OP] Well-Known Member
    Scott
    Los Angeles
    2017 TRD Off Road DCSB V6 MT
    My 62 GMC long bed 3/4 ton is down with a bad rear differential (can't really complain, it lasted 58 years) so I'm using the Taco this weekend to help someone move. It's annoying as all hell to try to carry things in the back of this truck. At 5.5 feet, the bed is way too short (I couldn't get a long bed double cab with a manual transmission) and he bedside tie-downs are useless because they flex the bed if you try to strap anything securely to them.
    I feel like the Taco is a great car and good for hauling camping gear, exploring off road and such but it really sucks when you need to actually carry things in the bed.
    I know, I know..."It's a mid-size truck". Well my 83 was a mini truck but with a 6 foot metal bed and external bedside tie downs it was FAR more utilitarian than my 2017.
    "Buy a full size truck" I already own one but as I said, it's down right now.
    I like my Tacoma for daily use, camping, off road etc, but trying to use it as a an actual pickup is a giant pain in the dick.
    I
  2. Aug 16, 2020 at 7:13 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I’ve used my truck for plenty of truck stuff. I do it every day :notsure:
    Kolter45, FredRed315, t2c and 30 others like this.
  3. Aug 16, 2020 at 7:14 AM
    t0nyvalenzuela
    t0nyvalenzuela Well-Known Member
    2019 Tacoma TRD OR DCLB
    Puck level
    I made the same mistake thinking it would be alright for my line of work. Well it isn’t. I work civil construction and all my counter parts all drive HD trucks. At this point it is what it is. I’ll trade it in eventually. TW isn’t a good place for guys that actually need use the truck. It’s more of an enthusiasts site. So good luck with your post.
  4. Aug 16, 2020 at 7:18 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    There is a 6' bed option. But composite beds really do seem like such a compromise.
    Time to move to Australia, they have proper beds on small trucks there.
    Or buy a Nissan . :laughing:
  5. Aug 16, 2020 at 7:27 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Guess you haven't see too many short bed full size pickups you know the 4 door ones? Maybe a few full size with the rotted out floor. A Tacoma would look pretty silly with a full size long bed. If you are going to crank the bejesus out of a ratchet strap use the tie downs. Only thing I have seen in a full size it a bit more width. No thanks if I need to haul more I'll use the trailer and leave the behemoth to someone with a large family.
    PzTank and AxisCab like this.
  6. Aug 16, 2020 at 8:00 AM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    I can live with the shorter box, and even the reduced width, but having a tonneau, the bed height is a bit of a drag. I came from a 15 Canyon and the bed was probably 3 or 4 inches higher, it makes a huge difference when loading gear such as coolers and gear boxes. I’ve had to replace both to fit in the shallower bed of the Tacoma.
  7. Aug 16, 2020 at 8:05 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    So I read, I couldn’t get the truck I wanted because it’s not made, but it doesn’t matter anyways, because I over strap stuff down so tight it bends my composite bed.
    Then others come one and say folks do not use their Tacoma’s as trucks. Well, can I carry 5 thousand pounds, nope. Can I carry a bed full of gear and pull a trailer full of gear and go 20 miles into the woods on trails, yep. But I guess that’s a job for a mini van.
    Now let’s see some Picts of that 62. And go to Home Depot and rent a “truck”
    RIX TUX, FredRed315, AxisCab and 6 others like this.
  8. Aug 16, 2020 at 8:06 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    There are better work trucks than a Tacoma, for sure. That’s not how they’re marketed, or how they’re designed. Suitable in most cases when length and weight is less of an issue.
  9. Aug 16, 2020 at 8:07 AM
    Spare Parts
    Southern Maine
    I think the 3rd gen bed is an inch taller than 2nd gens
  10. Aug 16, 2020 at 8:10 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    This
    gsubioguy and Ducman82 like this.
  11. Aug 16, 2020 at 8:11 AM
    Junior314
    Junior314 Well-Known Member
    Northeast
    '17 MGM OR DC/SB
    Cosmetic.
    Tacoma isn’t a heavy duty work truck, and it doesn’t claim to be.
    I use my Taco for “work” stuff all the time.
    Chew, BRFab, FredRed315 and 5 others like this.
  12. Aug 16, 2020 at 8:13 AM
    0xDEADBEEF
    I think his main complaint is that it has less utility than the same size truck from ~30 years ago, which is something I have have a hard time disagreeing with.
  13. Aug 16, 2020 at 8:17 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    OP, I really hope this didn't sneak up on you all at once.
    JmsWms, gsubioguy, RushT and 2 others like this.
  14. Aug 16, 2020 at 8:20 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Coming from a tundra i choose the access cab with the 6' bed. Its ok for most of my needs...sure i wish it had a wider steel bed, but the rest of the tacoma makes up for those short comings. Its really sad those gen1 tundras were discontinued for marketing purposes. Toyota got greedy like the rest of them wanting to sell more trucks.
  15. Aug 16, 2020 at 8:22 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Malvolio, hiPSI, Grindstone and 5 others like this.
  16. Aug 16, 2020 at 8:23 AM
    Shellshock
    Iowa
    If I need more than a 5 foot bed, I use a trailer :notsure:
  17. Aug 16, 2020 at 8:26 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Sounds like you're not good at buying the right truck for your needs.
    JmsWms, BRFab, Chew and 15 others like this.
  18. Aug 16, 2020 at 8:27 AM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    I use the bed floor tie downs to really secure stuff and then if I want to the bed side tie downs for a little extra security
  19. Aug 16, 2020 at 8:30 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    gsubioguy, Aws123, Malvolio and 6 others like this.
  20. Aug 16, 2020 at 8:32 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    5 days a week my Tacoma has no issues being used as a construction work truck.
    I can load all my work tools and materials for residential tile work.
    What do you expect when you buy a "1/4 ton" truck? Even my F-150 fell short of what the company F-350 can do.
    Buy the right tools for the job. Don't go out buy a miter saw and then join a miter saw forum to bitch that your old table saw was better at ripping boards.
