Frustrated that my truck isnt...well..a truck!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by msapers, Aug 16, 2020.
  1. Aug 16, 2020 at 9:42 AM
    #41
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You know I've made the same comment for years, they're truck like and pretty utilitarian but rated against other trucks they don't stack up for shit. That said, I don't really have a use for a truck, I own a trailer and a land cruiser if I need to haul things, the truck is just around for camping and exploring, I barely even drive it otherwise.
  2. Aug 16, 2020 at 9:43 AM
    #42
    rpowell25
    rpowell25 Well-Known Member
    Robert
    Walnut Creek, Ca
    2019 Tacoma DCSB TRD Off Road 4wd
    The list is long but distinguished
    OP's truck has patina, not rust and patina is highly sought after these days.
  3. Aug 16, 2020 at 9:48 AM
    #43
    bcgill
    bcgill Well-Known Member
    Ben
    Blacksburg, Virginia
    2019 SR 3.5L V6 4x4 Magnetic Grey
    I get it. I drive Rams and F-150s at work all the time. But my Taco does alright.
    The brush below is covered by a cargo net.
  4. Aug 16, 2020 at 9:51 AM
    #44
    Tripod1404
    Tripod1404 Annihilator tripod
    Would a similar sized truck of 30 years ago designed and marketed as mid-size truck though? A genuine question that I dont know. To me it looks like every truck built 30 years ago was designed and marketed as full size (even if dimensions they were smaller). Trucks and offroaders in general got a larger compared to 30 years ago. So I am not sure if comparing them based on dimensions is informative.
  5. Aug 16, 2020 at 9:56 AM
    #45
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Well you can base your trucks capacity based on the “size“ of it, but mine is based on the actual payload capacity and it well exceeds 1/2 ton ;)
    Math. I trust it. :)
    https://www.google.com/amp/s/www.au...pickup-payloads-worth-their-weight-159845?amp
    44-16 Taco and 02Duck like this.
  6. Aug 16, 2020 at 10:01 AM
    #46
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    mattleg likes this.
  7. Aug 16, 2020 at 10:04 AM
    #47
    davidstacoma
    David
    NC
    You can argue that all day long and I understand what you’re saying but at the end of the day a Tacoma 3rd gen payload rating still exceeds 1/2 ton, and that’s what it’s rated for, not a generally used “terminology”.
    Pinballwizard_king likes this.
  8. Aug 16, 2020 at 10:16 AM
    #48
    Edgar
    Edgar Well-Known Member
    San Diego
    2018 TRD OR 2wd DCSB MGM
    Bingo. OP, you can always get a real truck like a Honda Ridgeline...:playball:
  9. Aug 16, 2020 at 10:16 AM
    #49
    RedWings44
    Michigan
    Like I said, it doesn't mean what it used to. "1/4 ton", "1/2 ton" etc are now classifications. They don't mean carrying capacity and haven't in a long time. You can argue semantics all day, but things change over time and trucks are no different. The Silverado's payload capacity would make it a 3/4 ton truck, but it's still considered a 1/2 ton truck. If you want to consider GVWR, many 1/2 ton pickups have GVWR or over 7,000 lbs. That doesn't make it a 3.5 ton truck.
    Originally it was a nod to carrying capacity, but now it is a classification. Hell, the F150 is rated to tow over 10,000 lbs as a 1/2 ton truck. Trucks have become more capable over time, no question. But saying a 1/2 ton truck could haul only 1/2 ton has been out the window for decades.
    mattleg and davidstacoma[QUOTED] like this.
  10. Aug 16, 2020 at 10:23 AM
    #50
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    The bed is only 5 ft :confused:. Honestly you should know what you bought and know if it is good for your needs.
    Junkhead likes this.
  11. Aug 16, 2020 at 10:23 AM
    #51
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Number one selling midsize for a reason. People know what they're buying and it fits the bill. You're just not seeing things clearly.
  12. Aug 16, 2020 at 10:33 AM
    #52
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Me too. I've had trucks with 5', 5.5', 6', 6.5', 7', and 8' beds. If I can't fit it in a 5' bed I need 8' or a trailer. The 7' bed was a 1970's Jeep truck. But anything between 5'-6.5' isn't enough bigger to matter.
    When I made the move from a full size I figured out pretty quickly that I needed a trailer. It's not just the bed size, but the limited payload. With a 6'X10' trailer I can haul more cargo by both weight or volume than I could fit in the bed of a 1 ton truck with an 8' bed. And tow it with ease.
    I'm back in a full size now in addition to keeping the Tacoma. I still find it preferable to use the trailer. The ramp makes it a lot easier to load/unload heavy stuff and I don't beat up the bed as much.
  13. Aug 16, 2020 at 10:41 AM
    #53
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    My truck works fine as a truck . Try loading crap in a vw gti hatchback lol
    davidstacoma, Junkhead and RedWings44 like this.
  14. Aug 16, 2020 at 10:49 AM
    #54
    t0nyvalenzuela
    t0nyvalenzuela Well-Known Member
    2019 Tacoma TRD OR DCLB
    Puck level
    This is a great point!! My issue was that in other country’s a smaller trucks can handle a higher workload. In Kabul I drove a hilux that could conquer anything. I guess I wanted the Tacoma to be the same.
  15. Aug 16, 2020 at 10:50 AM
    #55
    davidstacoma
    David
    NC
    1/4 ton, 1/2 ton, etc. aren't official "classifications" they are just general common use terms, the only official classifications are the DOT classes 1-8.
    https://www.cjponyparts.com/resources/truck-sizes
    As the linked article states - "For determining truck sizes, the U.S. Department of Transportation uses a classification scale called Gross Vehicle Weight Rating. GVWR is defined as the total weight of a fully-loaded vehicle. The GVWR includes the weight of the chassis, body, engine, fuel, driver, passengers, and cargo but excludes trailers. If you subtract the curb weight of the vehicle from that equation, you’ll have the payload capacity. GVWR is largely a safety standard as overloading, or exceeding payload capacity, is not only dangerous, but it can harm your truck as well. GVWR can usually be found in your owner’s manual or on the doorframe of the vehicle."
    The official DOT classification for a Tacoma is 1, light duty. Now if you want to know the actual payload capacity for your Tacoma, you look in your door for GVWR and do the math as stated above. You can also check the Tacoma Product Specifications, here's the data for 2019 Tacoma:
    That's really all I have to say about it lol :)
  16. Aug 16, 2020 at 10:51 AM
    #56
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    This thread is still going?
    isn't the TL;DR :
    I didn't measure the W'xL' of my bed before I bought it and now I'm dealing with the consequences?
    Nuts.
    Rockefelluh likes this.
  17. Aug 16, 2020 at 10:51 AM
    #57
    Marshall R
    Marshall
    none
    The terms 1/2 ton, 3/4 ton, etc. haven't been relevant since the end of WW-2. None of the truck manufacturers have used that nomenclature for at least 50 years. It is just slang terms still used by the general public.
    The truck manufacturers use the term light duty for what we generally refer to as 1/2 ton trucks, and heavy duty, or super duty for bigger trucks. Ford uses the number 150 for their light duty trucks and 250, 350, 450, 550, etc. for their heavy duty trucks. Chevy and Ram use 4 digit numbers, 1500, 2500, 3500, etc. do describe the same class of trucks.
    The older Toyota trucks were classified as small trucks, not light duty, nor 1/4 ton. Starting with 2nd gen's they are classified as a mid-size.
    A better way to think of it is GVWR and payload.
    Modern Tacoma's have around 5400 lbs. GVWR and 1000-1300 lbs. payload
    What we refer to as 1/2 tons will be 7000-7500 lbs. GVWR and payload can vary between 1100-2500 lbs.
    What we refer to as 3/4 tons will have 10,000+ GVWR and 2500-4000 lbs. payload
    02Duck, RedWings44 and davidstacoma like this.
  18. Aug 16, 2020 at 10:59 AM
    #58
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    It's an old school term of truck capabilities. 1/4 is ranger, 1/2 is f150, 3/4 is f250, and 1 ton is f350.
  19. Aug 16, 2020 at 11:14 AM
    #59
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    3 pages and i still don't understand how these keep coming up, but i am never disappointed
    Grindstone and Junkhead like this.
  20. Aug 16, 2020 at 11:26 AM
    #60
    davidstacoma
    David
    NC
    We didn't want to disappoint you. We knew you needed to come in and diss some thread. Because see, you never disappoint, lol. ;)
