Frustrated with LR UCA bushing problems!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sprgrey, Mar 21, 2015.
  1. Mar 21, 2015 at 3:42 PM
    sprgrey
    sprgrey [OP] Well-Known Member
    Grey
    Conroe, Tx
    TRD, DBL, TOYO w/KONIGS
    Many, the list goes on..
    Just found out that the reason I continue to have tire and alignment problems is because my left UCA bushing is totally trashed! I bought a set of LR UCA's about 3-4 years ago and it's already trashed! :mad: Really!?!? Is this what I should expect after spending $450 on uca's to help my alignment? Is there anyway to get in touch with LR? So, I replace the entire arm, just the bushing? Frustrating to drop $450 on uca to help my alignment only to have it screw it up and now having to spend more $ to fix it! Any advice? LR any help here?!?!:frusty:
  2. Mar 21, 2015 at 3:43 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Contact SPC
    Get the new SpecRide bushings
  3. Mar 21, 2015 at 3:44 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    ^ yeap. And $450?! Good luck
  4. Mar 21, 2015 at 4:06 PM
    sprgrey
    Grey
    Conroe, Tx
    SPC?
    I'm willing to contact whoever to try and get this fixed. I read about some problems with these in the past, but of course, Now I'm finding out the hard way
  5. Mar 21, 2015 at 4:07 PM
    OZ-T
    Peter North
    British Columbia
    SPC is the manufacturer of the LR UCA's
  6. Mar 21, 2015 at 4:08 PM
    OZ-T
    Peter North
    British Columbia
  7. Mar 21, 2015 at 4:09 PM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    Does the newer models come with these bushing?
  8. Mar 21, 2015 at 4:09 PM
    OZ-T
    Peter North
    British Columbia
    Yes
  9. Mar 21, 2015 at 4:11 PM
    sprgrey
    Grey
    Conroe, Tx
    THANKS!!! Sure hoping they will work with me cause lets just say I'm not a happy customer.
  10. Mar 21, 2015 at 4:12 PM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    SPC had a bad batch of bushings a while back. Give them a call and they'll send you out a new set of their improved design.
    Here's my writeup on replacing the old bushings.
    I have heard of people asking for a replacement set as well. See if they'll go that direction. That way they just send you out a new set of arms and you send in your old ones.
    They really do have great customer service.
  11. Mar 21, 2015 at 4:38 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    my drivers side uca likes to squeak loudly and requires retightening of the bolt once a year when it starts making noise, otherwise they seem to be fine and track straight, but its still annoying.
  12. Mar 21, 2015 at 4:42 PM
    OZ-T
    Peter North
    British Columbia
    The UCA bolt is an OEM part , not part of the LR UCA
  13. Mar 21, 2015 at 5:47 PM
    sprgrey
    Grey
    Conroe, Tx
    I emailed SPC. I'll make an update post when I hear back to see what they offer as a remedy. Fingers crossed
  14. Mar 21, 2015 at 7:51 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'd suggest calling them. They actually answer the phone.
  15. Mar 25, 2015 at 11:03 AM
    OZ-T
    Peter North
    British Columbia
    and so ?
  16. Mar 25, 2015 at 11:55 AM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    And put their number on speed dial because your ball joints will wear out next. :mad::mad:
  17. Mar 25, 2015 at 11:57 AM
    OZ-T
    Peter North
    British Columbia
    No problems for me yet in over 4 years
  18. Mar 25, 2015 at 12:01 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    I just replaced my ball joints with warranty replacements from SPC. The swap took about 20 minutes, no pressing them out like other companies. I had one of the original batches of ball joints, that were proven to have issues.
  19. Mar 25, 2015 at 12:03 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    :rofl:
    That must be why my lower ball joints went out as well. :p
  20. Mar 25, 2015 at 12:33 PM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    I gave up on SPC.
    First the bushings were a “bad batch” which resulted in near catastrophic failure of the weld. But man they were great at SPC! Truck was only down a week while waiting for my free replacement and repairs! Sarcasm aside, I’m lucky no one died... In less than a year the driver side ball joint was loose and the truck could not be aligned. But SPC came through again with “upgraded” replacement ball joints. My front end mechanic showed me how the SPC ball joints are destined to fail due to excessive side loading that the offset puts on them.
    I’m sorry but I just lost faith in a company that uses it’s customer base for their R&D source.
