FRUSTRATED!!!
Discussion in 'Audio & Video' started by Fatherof2, Jun 14, 2013.
  1. Jun 14, 2013 at 2:11 PM
    Fatherof2
    Fatherof2 [OP] Well-Known Member
    Massachusetts
    2004 DC TRD
    I have a 2004 Tacoma Double Cab, and I just bought a system from Crutchfields. I cant find any help online on how to remove the door panels or the head unit!
    I cant get even one door panel off, so I switched to the head unit. Cant get the face plate off either! I dont want to snap or break anything, but it sure does not even seem like I am close. I HATE to pay someone 250 bucks to put this in.
    I have gotten a few parts off of each, but it is just not coming off.
    Does anyone have a link or any advice? Everything is different from the 05+. Lots of info for those trucks.
    Thanks for any advice.
  2. Jun 14, 2013 at 2:22 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Have you tried googling it?
  3. Jun 14, 2013 at 2:44 PM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Yes, I tried to Google it. Everything is for the 05 and up.
    Anyway, I just got the damned deck out!
    Now the wiring harness is an issue. How do I know which of the stock wires goes to the wires on my deck? There are a lot of wires to splice together. Front left, front right etc.
    Any thoughts?
    Thank you!!!
  4. Jun 14, 2013 at 2:53 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Did you try a search on here TW?
  5. Jun 14, 2013 at 2:56 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Can't help you on the head unit. But with the door panels you unscrew the door latch handle (1 screw). You don't have to take it all the way off if your just gonna take out the old speaker and replace it. Those door clips are kinda sturdy so you gotta pull hard. Once they are all out of place, lift it up a little to get the door lock out of its way. Oh, also you may need to pop the window/ door lock switch panel with a flat head, then unplug it. I think you do that for the front doors but don't exactly remember if I did that with the rear doors also. Most of the door clips will probably break so your gonna have to buy more at the auto parts store. If its at auto zone then the clips that work say "Nissan" on the box. Hope this helps... Good luck!
  6. Jun 14, 2013 at 2:57 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    buy this for the truck http://www.amazon.com/electronics/dp/B0002BEQJ8
    match the colors up from the headunit harness to the metra harness. then plug it into the stock connectors in the truck
  7. Jun 17, 2013 at 4:16 PM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Thanks for the help guys.
    I got the system in.
    For anyone else that ever tries to install speakers in an 04 Taco, just know that Crutchfields does not include brackets that will allow you to install the speakers.
  8. Jun 17, 2013 at 10:15 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    didnt critchfield include instructions on install? i know when i got mine from there they did. was super easy to install.
  9. Jun 20, 2013 at 4:47 AM
    atebit
    atebit What's all this, then?
    The basement of the Alamo
    18 Inferno TRD OR 4x4 AC
    If you call their tech support they should be able to send you their Master sheets on installing the HU. They will also walk you through any parts you don't understand.
    They are usually less helpful on door panel removal/speaker brackets but as a someone previously stated, that part is well do documented on TW.
