Frustrating oil leak - Valve cover
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4Paws, Apr 6, 2014.
  1. Apr 6, 2014 at 12:49 PM
    4Paws
    4Paws [OP] Active Member
    Scott
    Texas
    '04 PreRunner
    Hey guys,
    Anyone know the torque on the valve cover bolts for '04 Tacoma Prerunner V6?
    They keep working loose on me and then oil seeps out onto the exhaust manifold. Really getting frustrating. I'm afraid of over torquing them but I'm sick of smelling burnt oil. The main area now is the rear of the RH valve cover. (When sitting in cab looking forward.)
    Should I be doing something else? Replacing gasket etc..? I notice the bolt heads have what appear to be rubbe gaskets under them. Any advice is appreciated. Taking off the valve cover looks like it will be a bit of a pain.
    And how would I keep the bolts from becoming loose again? Or once I tighten them correctly will they stay tight?
    Thanks again,
    Scott
  2. Apr 6, 2014 at 12:53 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    Try using blue locktite.
  3. Apr 6, 2014 at 12:55 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I'm guessing that you need a new gasket. You have to be careful with how much torque you use on those bolts because it doesn't take much.
    It should be 13 ft-lbs. If you overtighten it, it can cause the gasket to leak as well.
  4. Apr 6, 2014 at 1:13 PM
    4Paws
    Scott
    Texas
    '04 PreRunner
    If I'm reading that right shouldn't it be 52 in lbs.? (For valve covers)
  5. Apr 6, 2014 at 1:15 PM
    4Paws
    Scott
    Texas
    '04 PreRunner
    Forgive me for asking this stupid question, but what exactly does that do? It doesn't make it impossible to remove them later?
  6. Apr 6, 2014 at 1:46 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Blue Locktite is removeable, red is the kind that requires heat to remove.
  7. Apr 6, 2014 at 2:39 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    You are correct. 52 in-pounds is the same as 4.33 ft-pounds.
  8. Apr 6, 2014 at 4:42 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    I have the 3.4 in my T4R and replaced valve cover gaskets, re-sealed the cam plugs and half moons. It was leaking from the rear and running down to my exhaust manifold and rear main seal (which is what I thought was leaking at first). Check the link below it may help.
    Link
  9. Apr 6, 2014 at 5:39 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Be carefull not to tighten valve covers to much or you will crack the valve cover. Sounds like you need new gaskets. Is it leaking by the firewall? If so take a small mirror,put it between firewall and valve cover and look for cracks. The area should be cleaned first with brake clean so you can see if it's cracked. Hope this helps.
  10. Apr 15, 2014 at 8:54 AM
    4Paws
    Scott
    Texas
    '04 PreRunner
    Ok, I finally got an opportunity to read through all this. It's like watching Youtube videos where one vid takes you to another vid and so on. I kept hitting links to additional great write ups. Lots of great info there.
    The key for me will be to try and have everything I possibly need before getting started. I hate having to jump into the wife's car and run into town and get some little part or sealant or something.
    I have a couple of questions.
    The half moons, I've seen them referenced a few times but I don't think I've seen where they actually go in the head. Are they dabbed with sealant?
    Also I watched a couple of videos last night and they both mentioned that no sealant should be used on the cover gasket itself, does everyone agree with that?
    Thanks (as always) to everyone that helped me out here and offered advice. A great community here.
  11. Jun 4, 2015 at 11:38 PM
    BlackBirtha
    BlackBirtha Well-Known Member
    2002 Tacoma Double cab
    What did you end up doing on the halfmoons? Just some sealant around them with the VC gaskets?
  12. Jun 5, 2015 at 6:18 AM
    4Paws
    Scott
    Texas
    '04 PreRunner
    I'm embarrassed to admit that I haven't dealt with it yet. I just monitor it, it's not leaking much. Some day. 160k miles.
  13. Jun 7, 2015 at 3:48 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    There are eight easily accessible valve cover bolts. In order to properly tighten all of the bolts, including the ones you can't see, you have to remove the intake manifold. By then you should just go ahead and replace the gaskets. There are sixteen total valve cover bolts in all.
  14. Jun 8, 2015 at 5:32 AM
    04Prerunnertaco
    04Prerunnertaco Well-Known Member
    Canton, GA
    2017 silver sky trd 4x2
    Same thing happened to me after hours with a flashlight and camera I found valve cover was actually cracked
