Frustration with this Ultragauge.......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rodallg, May 14, 2012.
  1. May 14, 2012 at 7:16 PM
    Rodallg
    Rodallg [OP] Well-Known Member
    CA
    Looking for some help here with this Ultragauge regarding the fuel calibration. I’m in the middle of a long road trip and I’m about to pull what hair I have out.
    Here it goes, after improperly calibrating the thing by pressing wrong buttons and zeroing things out before I left the trip I thought that going back after a fill up and resetting to full tank, zeroing the average MPG and resetting the calibration factor to 1.0 after a fill up. All is well until I fill up again and go to enter the gallons used I see the number in there that is no where near close to what I have so I change to the amount that I put in. Well what that does is just wack out the unit as far as the MPG and DTE. So I go back and zero out the average MPG and reset the calibration to 1.0. Do you see where this is going…..round in circles!
    Thinking I need to go in and reset the whole thing.
    Ant thoughts for help since I’m frustrated?
  2. May 14, 2012 at 7:24 PM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    how far off was your gallons vs fill volume? without the menu or manual in my hands, i feel there is another counter that also needs to be reset. I can confirm tomorrow if no one else chimes in.
  3. May 14, 2012 at 7:33 PM
    Rodallg
    CA
  4. May 14, 2012 at 7:49 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    It sounds to me like the gallons used for the calibration isn't resetting to zero but you're expecting it to. It won't reset to zero with a trip mpg reset. I ran into this when I moved the ultragauge from the honda to the tacoma.
    I wound up zeroing out every counter in the thing, which was ok because it was going into a new vehicle. I'm not sure which one did it, but eventually I got it to start at zero again. It doesn't explicitly say in the manual how to make that number start at zero, unfortunately.
    The closest references I can dig up:
    Calibration section says to start this process to report tank filled (top button, 5 sec) and then Zero Avg MPG, G/H.
    Gauge Description section says the Avg MPG is part of the 'general' gauge section rather than 'trip' and is reset like it says in the Calibration section.
    Something you can try if you can't find the one that wipes it down to zero: next fillup reset the calibration to 1.00 and record how many gallons it says. Write it down and be exact. Then next fillup, check the difference. The calibration factor will match exactly the number a calculator spits out if you divide the actual used gallons by the UG's measured gallons; then you can 'fudge' the calibration with a little trial-and-error to match that number your calculator spit out.
    Remember, once you set and forget that thing will count up forever.
    edit: the gauge you need to say zero to restart calibration is Fuel Used General. Zeroing procedure not described explicitly in either version of the user manual.
  5. May 14, 2012 at 8:03 PM
    iroh
    michigander
    tonneau
    If you ignore what it says for mpg, you can set both at the same time. There's no calibration interference between them.
  6. May 14, 2012 at 8:07 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It takes some getting used to and one wrong press (with no confirmation!) will start you over at square-one.
    I had finally pinned mine into a factor of around 1.085... then I zeroed MPG and it reset to 1.000 again.
    Of course, I did this about 60 miles into a tank, and it reset EVERYTHING.
    So today I fueled up and I played with the fuel amount until it reported 1.085 again, so hopefully I'll be close now.
    Short story... Keep all of your fuel receipts, or write down your exact fuel quantity for each refueling.
    Once you get 10 tanks or so, the gauge should be pretty well calibrated and you can just tell it "fill tank" and not have to go into calibration to add the fuel you just put in.
    But until you have the calibration dialed in, you need to track TOTAL fuel... so first tank you put in 10 gallons and the UG already has a 12 there, change it to 10 and it'll bump your correction factor.
    Next time you might put in 12 gallons... the UG might say 21... change it to 22, and it will further tune your correction factor.
    When your correction factor is dialed in for your truck, the number already in the UG will match your TOTAL fuel used from the first entry to and including the receipt in your hand.
    I save my "sent" text messages to Fuelly so if I lose one of my receipts I can manually add up my total.
  7. May 14, 2012 at 8:11 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
  8. May 16, 2012 at 10:15 AM
    rbishopp
    rbishopp Well-Known Member
    Rich
    Webster, NY
    2009 4WD Reg cab Taco. Keepin it simple.
    So far I've added an Advance folding bed cover and since removed it. Gave it to my son in Maine, he has an 05 2wd. GT perfect fit seat covers. Weathertech floor mats and window vent visors. Waag center brush/grill guard. Hose clamp tailgate mod. Turned off the seat belt chime. Added Ultra-Gauge. Trailer hitch. Softopper. Replaced sun visors with slide out style. Toyota bed extender. Had Firestone Destinations and now Michelin LTX AT2 in stock size. More mods to come; Fog lights, locking storage in bed, intermittent wipers. Now looking for Radio/HU upgrade. and maybe a lift way down the road.
    You all must have fuel level sensors in your tank. I don't. I just calibrated the distance so next I'll do the MPG. The directions seem straight forward but I haven't stepped through it yet.
  9. May 16, 2012 at 4:50 PM
    lickem66
    lickem66 Well-Known Member
    Portland, OR
    12 V6 DCSB 4x4 Sport 6MT
    Ride-Rites, OE tubes, Tri-Fold tonneau, extra bed D-rings, OE bedmat, center console organizer, rearview mirror bracket re-locate.
    I screwed it up the first time too. On the fuel used calibration page in the manual. do step 2 only the first time. I did it the third fueling and messed it all up and had to reset to 1.00 and start over.
    first fillup follow the calibration instructions in full
    second fill up skip step 2. The number of gallons shown should be fill up 1 + fill up 2. Make any corrections.
    third fill up same as second fill up but the number of gallons should now be the sum of the 3 fill ups.
    fill up 4 to N: same as 2nd and 3rd fill ups and keep adding the total gallons up and adjust the UG gallon settings.
    You should eventually get to the point where the number of gallons from your fill ups (from the receipts) should equal what UG is showing. Then you can stop calibrating because you are right on.
  10. May 16, 2012 at 5:27 PM
    rbishopp
    Rich
    Webster, NY
    Ok Thanks. I'll look for that. I recall seeing on the gauge that the auto fuel level stuff was already disabled because it was not found. I'll double check.
    Thanks. Got it mounted tonight.
  11. May 16, 2012 at 5:50 PM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    So when you fill upthe second time, lets say you put in 12 gallons, you will actually put in 13, and then on the third fill up, if you put in another 12 gallons, you would actually put 25 gallons into the ultragauge?
  12. May 16, 2012 at 6:17 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    No, you tell the UG exactly how much you put in.
    First fill up, if you put in 12, you tell it 12.
    Next time, you put in 12, the UG might already say 22 or 26.. change it to 24.
    Eventually, likely within 10 tanks (I screwed mine up and reset after 3 tanks), the number already in the UG will match your total.
    At that point, you're done with your calibration.
  13. May 16, 2012 at 6:24 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    My calibration continued to refine until I fucked up and zeroed the calibration.
    First tank my correction factor was around 1.1, 2nd tank it was around 1.09, 3rd tank it was around 1.088... then I fucked it up and had to start over.
  14. May 16, 2012 at 6:45 PM
    TacomaPrime
    Gregory
    Illinois
    So you don't just hold up to tell it you filled up after the very first time, you do have to go in and do step 3, until the calibration factor is 1?
  15. May 16, 2012 at 6:52 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Default calibration factor is 1.0, and on my truck was 2mpg high.
    First tank, it jumped to 1.10
    2nd tank, I put in something like 14 gallons, UG already said "21", but my 14 plus the first tank was 20 so I adjusted it to 20.
    3rd tank, UG said something like 33, but my total for the 3 tanks was 32 or something like that so again, I adjusted the UG down.
    Had to start over on the last tank, but knowing that I was between 1.08 and 1.09 before, I played with the fuel quantity to get it to that point. Hopefully it'll be dialed in after a couple more tanks.
  16. May 16, 2012 at 6:55 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It pulls the information from the fuel injector pulse timing.
    It knows how much fuel you are using... you just need to fine tune the calibration, which takes more than one tank.
  17. May 16, 2012 at 7:16 PM
    TacomaPrime
    Gregory
    Illinois
    So i guess i will have to keep a log of how many total gallons get put in.
  18. May 16, 2012 at 7:59 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I just keep my receipts in the coin holder pocket over the fusebox on the left.
  19. May 17, 2012 at 1:55 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Send it in for like $18.00 bones they will fix it.
  20. May 17, 2012 at 5:07 AM
    Rodallg
    CA
    Ok, I got the method now. That explains that after I zeroed it and the next fill up entry was good and the 2nd would be bad. Wouldn't it be nice if it was in the manual?
