Frustration with Transmission Service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PackCon, Nov 12, 2019.
  1. Nov 12, 2019 at 10:04 AM
    #41
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Ha, excellent point!
    PackCon[QUOTED][OP] likes this.
  2. Nov 12, 2019 at 10:09 AM
    #42
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Toyota recommends servicing the fluid. I did the flush through the transmission cooler lines as outlined in this forum. It was easy. I replaced all of the fluid with Valvoline Maxlife and a bottle of Lubegard. I also dropped the pan, cleaned it and the magnets and replaced the filter and pan gasket. Truck runs great. I have also done some drain and fills in between. Lots of bad information in this thread.
  3. Nov 12, 2019 at 10:44 AM
    #43
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Just do a drain & fill, be very sure you put in the same amount that drained out. You might do 2-3 drain & fills, at least a few days apart. I don't care if people say this is wasting new fluid, it is an effective way to get old stuff out and new stuff in, and you aren't really wasting much new fluid on the drain & fills. The "proper" way to check fluid level on the V6 models is more complicated but not too tough. Lots of tutorials/guides here on TW, do a search.
    BillsSR5, b_r_o and PackCon[OP] like this.
  4. Nov 12, 2019 at 10:58 AM
    #44
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    Ah yes. It is a change and not a flush. Sorry for that miss information.
  5. Nov 12, 2019 at 11:16 AM
    #45
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    This sounds like a success too though, that valve body was prob. going to clog enough from not flushing to shift poor.
    I'm in the change that stuff camp. Also in the 'put an aftermarket fluid cooler on every auto.' mob.
    0xDEADBEEF[QUOTED] likes this.
  6. Nov 12, 2019 at 11:20 AM
    #46
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Flushing is done through the cooler lines. You can exhange 100% of the fluid but the pan is not touched and the filter is left alone
    wheeliest likes this.
  7. Nov 12, 2019 at 11:26 AM
    #47
    PackCon
    PackCon [OP] Well-Known Member
    Connor
    2017 Subaru Forester Limited
    There are different ways to flush. Its argued the best way is with pan removal.
  8. Nov 12, 2019 at 11:29 AM
    #48
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What the hell is up with some of the replies in here? I can't believe some of the garbage I'm reading, it's slightly comical. Lifetime fluid.. :laugh: I can't believe some people are that gullible. This crap belongs in the 3rd Gen (still under warranty) section.
    / Exit thread
  9. Nov 12, 2019 at 11:31 AM
    #49
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sure you can do any combination flush/pan removal/drain and fill.
    In the shop, the term flush generally means a quick service without touching the pan
  10. Nov 12, 2019 at 11:32 AM
    #50
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
  11. Nov 12, 2019 at 11:36 AM
    #51
    PackCon
    Connor
    For real!
    I’ve read his recommendations on trans services and I’m trying to follow them!
  12. Nov 12, 2019 at 11:40 AM
    #52
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    FWIW i have a 2015 with about the same milage, i did the 3-4 qt spill and fill 6 months ago and everything has been fine.
    Get a little hand pump fluid exhanger and do it yourself, it can be a little nerve wracking if you've never done it but it really is easy on these trucks
    The only way you're gonna hurt something is if you hit the road when its not full. As long as you follow the instructions closely you'll be ok.
    You can drain the fluid into a clear container, measure exactly what came out and then put the same amount back in. That way, when you turn the engine on you know the pump wont be sucking air. From there, just pull the check plug while its running, feed it a little more until it dribbles out and then hit the road
  13. Nov 12, 2019 at 11:47 AM
    #53
    PackCon
    Connor
    I’m not doing this myself.
    I work two jobs, workout 14-20 hours a week, and still try to make time for my family.
    I do not want to waste any of my valuable and precious time working on my vehicle. I want someone else to take my damn money and do it for me.
    lil_buddy and wheeliest like this.
  14. Nov 12, 2019 at 11:53 AM
    #54
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Maybe if you did some of the work yourself you wouldn’t have to work 2 jobs.
  15. Nov 12, 2019 at 12:11 PM
    #55
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    :facepalm:
  16. Nov 12, 2019 at 12:19 PM
    #56
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Are you enjoying all the "I've read or, I've heard or, just do it yourself" replies? :D
  17. Nov 12, 2019 at 12:22 PM
    #57
    gearcruncher
    Canadain bumper technician
    There are 2 types of flushing machines . One type of flushing machine uses the cooling lines to replace the fluid . I dont like these .Then there is a style of flushing machine that functions with your transmission pan and filter removed . This machine connects to the transmission filter sump and removes the remaining fluid from your torque converter and cooling system . Find a shop that uses this style . Why ? because your transmission pan will already be off and there will be no risk of flushing crap from the pan and filter through your valve body . A lot of transmission shops use this style of transmission flusher . Most shops build thier own flushing machine
  18. Nov 12, 2019 at 12:33 PM
    #58
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    There you go, just what we were looking for !!!
    PackCon[OP] likes this.
  19. Nov 12, 2019 at 12:36 PM
    #59
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Every 15k, lol. Piece of mind or not, at 15k it's just a complete WASTE of time and money. Why not just go every 5K, or hell, why not every 2.5K
    BillsSR5 likes this.
  20. Nov 12, 2019 at 12:39 PM
    #60
    TacomaSport86
