FS: ’98-’04 Rear Leaf Springs 2"-3" Lift
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Digiratus, Mar 11, 2011.
  1. Mar 11, 2011 at 10:39 AM
    Digiratus
    Digiratus [OP] Adventurer
    Roaming the PNW
    The RedHead
    These were on my truck for about 3 months, about 5,000 miles. They will fit all 1998 thru 2004 6 lug models and are in perfect condition.
    I bought these springs from Northwest Off-Road Specialties last April. NWOR claims they give 2” of lift, on my truck they gave closer to 3”. They are designed for carrying extra weight, with a 700 lb. overload rating.
    I am willing to ship.
    SOLD!!!
  2. Mar 11, 2011 at 10:48 AM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    Hmm sounds like a good deal
  3. Mar 11, 2011 at 6:58 PM
    rayny1014
    rayny1014 Well-Known Member
    new york
    04 trd xtra cab 4x4
    pm sent
  4. Mar 13, 2011 at 11:23 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have responded to your offer.
  5. Mar 14, 2011 at 8:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
  6. Mar 14, 2011 at 10:52 PM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    would these work with stock shakles? and you say they give three inches of lift cause i currently have aal's and would like to change over eventually but not sure if i can come up with the money anytime soon. ill just keep in touch and let you know if i can swing the cash.
  7. Mar 15, 2011 at 2:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, these work with stock shackles. That is the way I used them.
  8. Mar 15, 2011 at 2:58 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Why are you getting rid of them?
  9. Mar 15, 2011 at 3:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hey Phil, you looking for some springs? I'll make you a special deal if you are sinces your almost local. Besides, gotta take care of the Wa guys. :D
    To answer your question, these springs when installed on my truck gave me almost 3" of lift in the rear. I did not want to crank up my SAW coilovers that high to compensate, just to make the truck level. I only wanted 1 1/2-2" at the most. I ended up replacing these with an 8-leaf pack from Alcan last summer.
  10. Mar 15, 2011 at 4:30 PM
    tacomakid96
    Phil
    Out n' about
    I appreciate that Mike, If I was in the market I would buy these in a heart beat. But the truth of the matter is I just got new leafs:eek: Plus my trucks only lifted 2.5'' for now anyhow.
    Thanks for the potential deal, us Washington guys gotta stick together:D
  11. Mar 16, 2011 at 9:59 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Come on guys! :D I know one of you needs these.
  12. Mar 16, 2011 at 10:02 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Haha I do! But as always I'm strapped for cash. Glws
  13. Mar 16, 2011 at 10:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Max! You need these bad! I know you do. :thumbsup:
  14. Mar 16, 2011 at 10:11 PM
    malander
    max
    01 limited trd 4x4
    Haha yeah yeah I know I know. I'm pretty sure I'll have an aal, block and extended shackle on my driver side spring and an aal and shackle on my pass side sometime in the next month or two :/. That is unless these babies don't sell and I get the money for em :D
  15. Mar 16, 2011 at 10:14 PM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    i really want these. If in a couple of weeks you still have these, I will PM you.
  16. Mar 17, 2011 at 8:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hey man, sounds good. Let me know.
  17. Mar 17, 2011 at 10:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    fit a 96 maybe? or only 98+?
  18. Mar 17, 2011 at 10:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    They are too long for the '95.5-'97 models. The springs for those are about 4" shorter.
  19. Mar 18, 2011 at 11:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    darn...sometimes i wish i had a 98!
  20. Mar 20, 2011 at 10:52 PM
    Digiratus
    Roaming the PNW
    The RedHead
