FS - 07 Double Cab
Discussion in 'Buy / Sell / Trade' started by Fire931, Apr 30, 2010.
  1. Apr 30, 2010 at 9:41 PM
    Fire931
    Fire931 [OP] Well-Known Member Vendor
    VA
    00 4Runner
    2007 Toyota Tacoma Double Cab Short Bed Sport - Speedway Blue
    21,000 miles!!
    TRUCK OPTIONS:
    -Power windows, locks, mirrors
    - Cruise Control
    - Tilt Wheel
    - Roof Rack
    - 400 watt inverter w/ 110v outlet in bed
    DRIVE TRAIN:
    - 4.0L V-6 stock, running Mobil 1 Synthetic oil
    - 6spd. Manual transmission, running Amsoil Synthetic oil
    - Inchworm Crawler w/ 2.28 gears
    - Inchworm Lefty transfer case w/ 4.7 gears & twin sticks, Marlin 30 spline front and rear outputs
    - single piece rear driveshaft with double cardigan joint and HD u-joints
    - ARB rear locker
    - all breathers extended up w/ filters
    - Spal electric fan w/ variable speed controller, interior override switch
    WHEELS/TIRES:
    - Mickey Thompson Classic Lock 16x8
    - Mickey Thompson MTZ’s 285/75R16
    - matching spare
    SUSPENSION:
    Front:
    - Fox 2.0 remote resi. Coilovers
    - Total Chaos uniball UCA’s
    - sway bar removed
    Rear:
    - Alcan AAL
    - Bilstein 5125 shocks
    - ATO shackle flip
    - braided stainless extended brake lines
    ARMOR:
    - ATO front bumper, Smittybuilt XRC8 winch, Amsteel Blue synthetic line, interior controls
    - 4xInnovations DOM weld on sliders w/ kick out
    - Rear ATO wrap around high clearance bumper w/ hitch, flood lights, shackle mounts, hi lift notches, bedside protection, tire carrier, rear winch mount
    - ATO front skid
    - ATO Transmission Skid
    - ATO gas tank skid
    - One of a kind custom flat belly crossmember ans skids!!!!!!!
    EXTERIOR MODS:
    - Front, Middle, and Rear Halogen rock lights
    - Black Billet Grill w/ hood scoop insert
    - Black head light mod w/ Sylvania Silverstar Ultra bulbs
    - custom exhaust crossover w/ Flowmaster 50 series truck/suv muffler
    - led bed lights
    - UWS chest toolbox
    - ammo can on fender well
    - Hi Lift mount on pass. Side bed
    - Viair 450 constant duty compressor mounted in driver side bed cubby w/ 2.5 gal. tank under bed, air chuck inside bed
    - Toyota rubber bed mat
    - vent visors on all 4 doors
    - 50% tint on front windows
    - Sockmonkey Tacoma decals
    - Sockmonkey Hood Scoop Blackout
    - Safari Snorkel
    INTERIOR MODS:
    - Weather Tech floor liners front and rear
    - Toyota door sill guards
    - blue led floor accent lighting tied in with dome light
    - 2 110v outlets on rear of center console tied into stock inverter w/ 400 watt anytime mod
    - 12v cigarette plug and 5v USB plug in rear of center console always on
    - Mag light holder at drivers side back door
    - Uniden 510 cb mounted in center console
    - blue backlight gauge cluster w/ white needles
    - blue backlight on window switch, steering wheel controls, clock
    - Aeroforce Interceptor gauge and Air pressure gauge mounted in A-pillar gauge pod
    - Carling switches on left side of dash and overhead console
    - 2 Painless Wiring fuse blocks mounted under hood w/ Painless Wiring relay bank
    - custom cupholer area to accommodate twin sticks from tcase
    AUDIO:
    - Kenwood DDX 7019 in dash DVD player w/ 7” touch screen, xm satellite radio hooked up, and ipod audio/video connector in center console
    - Rear backup camera
    - Pioneer Premier TS-C720PRS front components
    - Pioneer Premier TS-D601P rear 2 way speakers
    - Eclipse XA4000 4 channel amp
    - 10" Infinity self powered sub
    - Mr. Marv speaker adapters used on the doors
    - Elemental Design sound deadening on all doors and rear cab wall
    Truck has the normal light pin striping from trail riding. A few heavier scratches here and there but most would buff out. There is one small dent on the drivers side bedside just behind the gas door.
    This truck goes like no other on the trail. The crawler still amazes me as to the capability it adds to the truck.
    The only bad things on the truck are as follows:
    - Leather shifter boots for twin sticks aren't finished
    - Some rock rash on the trim rings on the wheels, can be easily replaced at minimum cost
    Will also consider partial trades of either a 99-02 4wd 4Runner or 89-95 Extended Cab Pickup
  2. Apr 30, 2010 at 9:48 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    :eek: Nice! Good luck with the sale.
  3. Apr 30, 2010 at 9:50 PM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    The truck that made me decide on Classic Locks! :D
    Good luck with the sale....beautiful rig.
  4. Apr 30, 2010 at 10:03 PM
    Fire931
    VA
    00 4Runner
    thanks guys!
  5. Apr 30, 2010 at 10:07 PM
    Fire931
    VA
    00 4Runner
    well i had purchased a blank from a prerunner and took the switch out, but i had mounted a cell phone mount there so that piece has holes in it now so i just popped the switch back in instead of having a panel with holes in it.
    edit..... if your referring to the 4x4 toggle in the overhead that locks and unlocks the ADD
  6. May 1, 2010 at 12:10 AM
    Fire931
    VA
    00 4Runner
    no... the ADD is basically the extent of locking your hubs on the old trucks
  7. May 1, 2010 at 1:00 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    why are you selling it!?!?!?!?
  8. May 1, 2010 at 1:15 AM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    omg your really selling this beast!?!?! damn man good luck sick taco ever
  9. May 1, 2010 at 1:45 AM
    Fire931
    VA
    00 4Runner
    time to start on something new
    thanks
  10. May 1, 2010 at 7:16 AM
    SACTOWN
    Greg
    You want a stock taco. I got one if you want to start over!!
  11. May 1, 2010 at 10:12 AM
    Fire931
    VA
    00 4Runner
    na thanks... but you can still buy mine if youd like
  12. May 6, 2010 at 9:31 AM
    Fire931
    VA
    00 4Runner
    bump....
  13. May 6, 2010 at 9:45 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Are you going to buy another tacoma?
  14. May 6, 2010 at 6:28 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    That is one nice truck, wish i had the money to do that to mine. Where in VA are you?
  15. May 6, 2010 at 6:28 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    would love to have that truck sucks being in high school with no money
  16. May 6, 2010 at 6:35 PM
    113tac
    Stephen
    Northern Virginia
    x2!!!
  17. May 7, 2010 at 6:23 AM
    Fire931
    VA
    00 4Runner
    located in lexington. thanks guys
  18. May 7, 2010 at 8:01 PM
    Spootypuff
    Spootypuff Well-Known Member
    Jacksonville, FL
    SWB Sport Double Cab SB 4x4
    Satoshi
    I don't suppose you want a BMW...
  19. May 10, 2010 at 8:24 PM
    Fire931
    VA
    00 4Runner
    sorry no use for a BMW unless its brand new :D
    bump bump...
  20. May 10, 2010 at 8:26 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Trade? Same color, shorter wheel base? PLEASE:eek:
