FS: 10g steel skid plate
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Matt123, Jul 9, 2012.
  1. Mar 6, 2017 at 12:20 PM
    #1501
    Matt123
    Matt123 [OP] Well-Known Member
    www.bpfabricating.com
    West Coast
    Toyota Tacoma
    Man I missed a whole page of comments.
    We really only offer that if there is a long lead time. Although will be having a sale very very soon.
    Any paint will work, rattle can is nice because you can just touch it up when need be.
  2. Mar 7, 2017 at 11:33 AM
    #1502
    basically_stock_
    basically_stock_ 3rd Shift Lurker
    Eric
    Iowa
    2009 TRD Sport, Free & Clear
    2" lift, SCS Ray 10, Falken Wildpeak's
    This is what i figured they were for, i was considering just using the spacer and no washers but didnt want the skid to be too close to the bumper and chance rubbing.
    Ill get some better photos with my camera someday.
  3. Mar 7, 2017 at 11:44 AM
    #1503
    Walston9
    Walston9 Member
    Will
    2007 Tacoma Pre-runner
    URD CAI, Magnaflow headers & exhaust, URD MAF, HID, DVD deck & sub
    You have a picture of the skid on a Tacoma?
  4. Mar 7, 2017 at 12:05 PM
    #1504
    basically_stock_
    Eric
    Iowa
    Post #1500
  5. Mar 9, 2017 at 9:30 AM
    #1505
    Matt123
    West Coast
    Toyota Tacoma
    If there is an interest I can definitely make that happen.
    Showing some tundra love.
    Currently having a 15% off sale guys. Use Coupon Code: "SPRINGSALE" to get 15% OFF all BPF products.
    Shop at www.bpfabricating.com
    MadDaddy and Byb127 like this.
  6. Mar 20, 2017 at 1:46 PM
    #1506
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    I would be interested.
    Byb127 likes this.
  7. Mar 22, 2017 at 11:09 AM
    #1507
    babylon5
    David
    question regarding the tow hook..
    mentions on web site "Utilizes factory hardware" so I used the existing bolts..
    So what does this mean?? Off Road versions will need M12x1.25x40mm Bolts.
  8. Mar 26, 2017 at 10:18 AM
    #1508
    babylon5
    David
    just finished installing the skid plate and its almost a stealth install. barely visible at all.
    has anyone discarded the original splash tray or whatever it is an just installed the skid plate.
    I know it would have been much easier to install without the tray since teh hard part was lining up the holes in the plate with the holes in the frame. i will probably replace the rear oem bolt/screws with real bolts since they are really quite short.
  9. Mar 31, 2017 at 4:22 AM
    #1509
    basically_stock_
    Eric
    Iowa
    I removed the factory skid plate, probably keep it around for a while
  10. Apr 1, 2017 at 11:02 AM
    #1510
    AMTaco89
    AMTaco89 Well-Known Member
    Alex
    Santa Rosa, CA
    2015 Black Tacoma TRD Off Road 4x4
    MRBP Axle Dump Exhaust, URD True Cold Air Intake, URD Y-Pipe, URD Maf Calibrator, XTP Manifold Spacer, Blacked Out Grill Surround, Blacked Out Rear Bumper, BPF Front Skid, Avis In Channel Window Deflectors, Built Right Fabrication UCA, King Extended Travel Coilovers F/R, Icon 1.5 Inch AAL, 17 inch Method Double Standard Wheels, BFG K02's 285/70/17, 32 Inch Lower Grille LED Light Bar, OEM Roof Rack
    Just purchased!!! Cant wait to install. On the website it says that it mounts over the factory skid? Is this true? Thank you
  11. Apr 4, 2017 at 10:14 AM
    #1511
    Matt123
    West Coast
    Toyota Tacoma
    Only the off road versions require different hardware, as the bolts are longer then the Sport/SR5's due to the factory hook.
    The skid plate works with or without the factory skid pate.
    I will look into making an extended skid plate, but it might take a couple months as I have a couple projects currently on the go.
  12. Apr 4, 2017 at 10:39 AM
    #1512
    AMTaco89
    Alex
    Santa Rosa, CA
    Okay awesome. How long is the lead time for the skid? Or are they already made and ready to ship? Thanks
  13. Apr 4, 2017 at 2:52 PM
    #1513
    MethodMan
    MethodMan Well-Known Member
    DCLB TRD Sport
    OME 885s, Dakar leafs, Cooper ST Maxx Tires, TRD Baja wheels, TRD Pro grille
    Id be interested in a extension T case skid.
    Byb127 likes this.
  14. Apr 4, 2017 at 5:23 PM
    #1514
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    Wife just asked what I want for my birthday.
    Byb127 likes this.
  15. Apr 4, 2017 at 10:48 PM
    #1515
    AMTaco89
    Alex
    Santa Rosa, CA
    Let's do it!
    Byb127 likes this.
  16. Apr 6, 2017 at 10:48 AM
    #1516
    Matt123
    West Coast
    Toyota Tacoma
    Yep these are ready to go.
    MadDaddy likes this.
  17. Apr 6, 2017 at 1:50 PM
    #1517
    AMTaco89
    Alex
    Santa Rosa, CA
    Okay cool email says i should receive it on saturday!! I can't wait
    Matt123[QUOTED][OP] likes this.
  18. Apr 8, 2017 at 11:17 AM
    #1518
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    Anyone had problems with the passenger side bolt? I pulled the factory skid and tried to screw it in by itself because I was having no luck and it won't go in the HOLE!!, the driver side works fine. I use the OEM bolt and it was all good.
    **update**
    motherf@#$ing son of @#$@# piece of @#$@# @#$hole !@#$.
    So the nut was welded a bit wrong so have to angle the bolt a certain way to get it in the hole (maybe she says that every now and then)...anywho I got the skid plate on. Pictures to follow soon.
  19. Apr 8, 2017 at 12:10 PM
    #1519
    Matt123
    West Coast
    Toyota Tacoma
    How do the threads look on the bolt? do they match up with other one? The bolts aren't tapered like the OEM ones you need to racket them in almost right away. Shoot me an email if your having further issues bpfabricating@gmail.com. The bolts are M8-60 incase it needs to be replaced.
  20. Apr 8, 2017 at 12:57 PM
    #1520
    Superman910
    Eric
    Northern Virginia
    So the threads matched for the most part, maybe a little off from each other, but the main problem was the nut was welded where there was a bit of a shift, the tapered bolt had no problem going in cause it acts as a sort of a guide, but the ones you supplied, I had to apply some swearing and force it in there then ratchet it. One bolt worked better than the other, but they both ended up working just fine, needless to say its mounted, my bully aka sissy bar has been retired, and I will post pics in the next free.
    Oh and I banged the shit out of my forehead with the skid plate gave way the first time due to me not realizing the bolt wasn't lined up...I scared the crap out of a lady walking by when she heard a series of swear words chained together.
